Question about SanDisk Sansa e250 MP3 Player
Sync does not work
I cannot properly format my mp3 player, nor can I sync any files to it anymore!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 03, 2008
Why does file format not supported appear on my mp3 player
I went to "more options" under the sync tab in windows media player, then clicked on "rip music" and clicked on format and chose mp3 then apply...it was a simple solution to what seemed like a huge problem...
Jun 11, 2009 | Philips GOGEAR SA6045 MP3 Player
File Format not supported
You have to be sure that the files are all mp3 files, or wma (windows media audio). Check the rip settings in Windows Media Player. If you rip CD's in a format other than mp3 or wma you will not be able to sync the files to your player. I would suggest sticking with mp3 - as mp3 files are compatible with any player, including ipods.
Apr 06, 2009 | Philips GoGear SA3245/37 Digital Media...
I have not been able to copy CD's onto the MP3 player. I keep getting a formatting error when trying to convert even though I am using WMA and have tried MP3.
mdcope2 - delete the msuic files that you already ripped from CD off the GoGear. If you Rip a song in WMA, and then re-rip it in Mp3 format, when you go to sync the mp3 file, the GoGear will basically ignore the new file, because it thinks that the file is already on the GoGear since it has almost the same name. Once you have deleted the affected songs, re-Rip the songs in Mp3 format using Windows Media Player. This time, when you go to sync the songs, it will work.
Guest - to load video files onto the GoGear, you have to convert and sync them through the Philips Media Converter - no other method will work.
-Tha Mp3 Doctor
Mar 02, 2009 | Philips GOGEAR SA6045 MP3 Player
TrekStor emo won't show or play mp3 or WMA files.
I had the same problem. The solution for me was that the files on my computer hard drive were set to play on the realplayer format. Once I changed the format to play on the windows media format, it started saving to the Emo. I hope this helps you.
Dec 16, 2008 | Trekstor 74412 i.Beat emo MP3 Player
MP3 PLAYER
Reformat the player and start over.
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 06, 2008 | Audio Players & Recorders
Incorrect Format Please Reformat the Player
-Tha Mp3 Doctor
Apr 24, 2008 | iLO MP3 Player
Accurian mp3
-Tha Mp3 Doctor
Mar 21, 2008 | iLO MP3 Player
Annoying Memory Problem
-Tha Mp3 Doctor
Oct 12, 2007 | iLO (2 GB) MP3 Player
Empty song list
Here's what happened: When you first synced your player to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the player. Now, every time you sync you device, it adds every new file from your computer into the player automatically. It will even delete songs from your player that were on there before.
Go into Windows Media Player 11 with your player connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding/deleting songs/files you don't want into your player.
-Tha Mp3 Doctor
Apr 10, 2007 | Philips GoGear HDD6330 MP3 Player
Formatting and error codes
-Tha Mp3 Doctor
Oct 02, 2006 | iRiver iFP-895 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
