Question about Sony Playstation 3 (PS3) Console
Playstation 3 picture reset
I just hooked my ps3 up to my tv and switched the video setting to hdmi but saw nothing but blur i want to reset it back to the normal setting. how do i do this i reset it and held the button for 10 seconds like others had said but it didnt work.
    Champion:
  • 207 Answers
Hey kg did you shut the system off then wait for the red light to appear then hold it down until it beeps?
if you did this several times and it did not work try changing the tv back by going into settings and switching it back over.
Posted on Jul 01, 2008
The PS3 switches on, lights up, drive and disc drive working but No Signal on TV. Saw HDMI cable solution previously posted. Does that work for SCART also?
yes just change hdmi for the word scart
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Reset defalt settings..... and the screen is telling me to plug in controler and then press the ps3 button and nothing happens
unplug the controller and take a pin and press the small button on the back of the controller to reset. i also had this problem with mine.
May 31, 2010 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
I had ps3 hooked up to 720p tv then hooked it up to 1080p moniter now it won't show a picture on 720p tv
you have to switch it back to 720p mode before disconnecting it from the 1080p television. If you're using HDMI, and then switching back to the a/v connectors, then you have to switch the output settings of the ps3 from hdmi to a/v as well.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
Origiannly had my son's PS# hooked up to our HD TV
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • From: http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=967&p_sid=1frk_Cuj
    Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Apr 06, 2009 | Sony Playstation 3 (PS3) Console
    Playstation 3
    try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
    Jan 11, 2008 | Sony Playstation 3 (PS3) Console
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Ps3 hdmi-av
    i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
    • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
    Hope it helps =)
    Nov 17, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
