Question about Goldstar DH3010B Dehumidifier
Goldstar dehumidifier runs
Runs, dosen't shut off
  • Goldstar Master
  • 43,501 Answers
There are many reasons for a dehumidifiergoldstar dehumidifier runs - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Jul 13, 2010
I have a goldstar dehumidifier that runs for a couple min. then turns off. I unplugged the rheostat wires from the mother board and it runs just fine. Does that mean if I replace the rheostat switch the...
Runs for a few minutes then shuts off, easy fix. First, remove water catcher and slide filter out and clean it. Then find the two screws that hold on the front panel remove front panel. Make sure the unit is un-plugged. The humidity control dial has two wires connected to it. clip the inner wire. This will keep the unit on full. You could replace the humidity control dial, but why bother?
Dec 12, 2011 | Goldstar DH304 Dehumidifier
I have Goldstar modle # DH 305y7 it does not run
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 01, 2011 | Goldstar DH304 Dehumidifier
Runs for a couple minute then shuts off
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Aug 29, 2010 | Goldstar DH304 Dehumidifier
Bucket is empty, fan comes on to start up runs for about 2 seconds and shuts system right back off
heatman101
Aug 26, 2010 | Goldstar DH504EL Dehumidifier
Goldstar dehumidifier won't run
Sounds like this unit developed a freon leak and that will make it run hot like that...cheaper to replace it then to repair...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
heatman101
May 14, 2010 | Goldstar DH504EL Dehumidifier
Goldstar dh305y6.will olny run sometimes then shuts off it does collect water but it will olny run a few minutes. other times will not run at all it a dehumideifier
Sound like you need a good cleaning of the evap and condensor. The make sure the fan is running. If nothing runs then check your thermostat.
Aug 31, 2009 | LG DH30 GoldStar Dehumidifier
Goldstar dehumidifier won't shut off automatically
Mine does the same thing and alos ices up. What is the problem?
Jul 11, 2009 | Goldstar DH304 Dehumidifier
Settings
As an example, if you want the Humidity % factor to be 50%, 70% or whatever % you want in the space in question to be, set it at whatever % you want the space to be and the humidifier will work until it reaches that setting. It will then shut down until it determines that the humidity has reached a level that requires dehumidifying again. You can set it to run for 2 hours and it then it will shut down for 2 hours, or you can set it to run for 4 hours and then it will shut down for 4 hours. You just have to decide just how humid the area is that you are dealing with.
Go to; www.shopping.com and search for Goldstar Dehumidifiers and you can read comments by others who have purchased this brand. I, myself have one in my celler that has been running for over two years and it has made a world of differance down there.
Good luck. :)
May 14, 2009 | Goldstar Dehumidifiers
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Sep 13, 2008 | Goldstar DH304 Dehumidifier
Runs all the time, not collecting water
I don't know your particular unit, but my guess is that the compressor is bad. If it is old, it may not be worth fixing.
Sep 19, 2006 | Goldstar DH504EL Dehumidifier
Goldstar DH3010B Dehumidifier Logo
164 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
