Question about Curtis-Mathis CM27101S TV
Horizontal adjustment. tHE PICTURE goes above and below the screen, so the heads are being cut off, there are no visible knobs to adjust the horizontal settings. HELP
  • 2 more comments
  • Shawdom1 Nov 16, 2008
  • mikept Dec 12, 2008
    The picture goes above and below the screen. How is it adjusted?
  • sarthur203 Dec 27, 2008
    the bottom of my screen is over lapping on itself.
  • jennifercrow Jan 24, 2009
    Mine is doing th same thing.
  • 3 Answers
I have the same problem. Just what is the repair?
Garry Meyer
Posted on Jul 27, 2008
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
Can headlights be manually adjusted on MK4 Renault Clio's?
hi kate the vertical and the horizontal(meaning left/right) can be adjusted there are two screw adjusters if you check on top of crossmember that is above radiator/head lamps there is a hole above each head light and below tese holes you will see x/head screws one for each h/lights vertical up/down adjustment screw down raises beam and no need to adjust horizontal however ? this adjustment is best done using correct equipment and if not done correctly ? cars next mot which checking h/lights is part of test i would advise having adjst ment checked 1st b4 altering hope this helps ? best wishes from the uk
Mar 21, 2010 | 2006 Renault Sportwagon
How do you adjust the picture? Mine is zoomed in
Is this set using a cable or satellite box? I looked at the owners manual and did not see any format adjustments. If it is hooked to a box, check the settings there.
Oct 14, 2009 | Sony KP-61S75 TV
This unit will need to be opened up to adjust that horizontal problem, There are 3 knob looking things in the unit with a phillips head adjust those until the screen moves up. I would not do it if you do not know how I would take it and pay $15 bucks to have it done. If you find this information useful? please rate Fixya if you still dont findit fixing the problem rate 1 knotch below fixya.
Apr 24, 2009 | RCA 14F512T 14" TV
Viewing mode will only go from zoom to wide!!!! please help
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Further assistance needed
I just replied you and here once again...
Please pull front speaker grill and find focus block, fixed at corner having 6 control knobs on it.
Find Blue Screen control knob there.
Put your TV in AV mode to get dark screen and just press Display button on remote to have AV display.
Now slightly rotate control knobs counter clock wise until thin lines (retrace) disappear. Job is done and put back speaker grill, press display button again to disappear screen display.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Picture is cut off on the bottom of my Hitachi 57F500
Verical position is hard to adjust and is in service menu. A service manual will get you there, but you might get lucky with the vertical size adjustment. If you open the front of the TV, the vertical size is adjusted with a knob on the deflection board. Remove the speaker grille and take off the access panel. You will see two knobs, one horizontal and one vertical. Be careful, those red wires have 30,000 volts on then, don't touch anything but those knobs. If its just an adjustment, the v-size knob will fix. Set it so ESPN ticker is just above the bottom of the screen. *Service mode - the manual tells little but entering is done by "press and hold the input button, press the power button, release both after you hear HV come up" .. the v-pos parameter is in there, but this manual doesn't say where or how to adjust, procede at your own risk. If you get into trouble, pull the power so you don't save any settings. I believe you just navigate through the menus to find the parameter and use arrows to adjust. Enter may save. Sorry the service manual I have tells nothing much.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Bottom of picture is not all the way visible.
you need to adjust the vertical setting on your tv set. are you a tech person? if you are just follow these instructions. turn the tv off and unplug it. take the back of the tv off. you will find the screen and the crt tube. on the tube, you will find the yoke of the screen follow the four wires coming down to the board. you will find small knobs. you will find writing next to these knobs. look for vertical phase. once you find it. now you have to plug the tv and do this live. be carefull. once you see the picture on the screen. adjust this knob till you see the bottom. good luck
Apr 17, 2007 | Orion STV2763 27" TV
Curtis-Mathis CM27101S TV Logo
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
