Question about SanDisk Sansa e250 MP3 Player
Sansa fuze 2gb
I just bought my sandisk and i plugged it up to my computer and it said that it was connected so i started to upload songs on it and then the screen went blurry so i reformated the sandisk but the screen is still blurry and i cant see what i am picking
  • arvindsuk Sep 06, 2008
    i hav sansa fuze.... same prob wit me... my player wen connected wit comp shows no sign..... it wld show d status has connected in player bt its neither chargin nor detectin in comp.... i hav nt tried pluggin it in another comp.... i cant go fa recovery mode as i don hav vol increase button instead its of rotatin type..... i cant use it because of tis prob fa more than two mnths.... pls giv me a solution as soon as possible... thanks...
  • arvindsuk May 11, 2010
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 03, 2008
I cannot upload any videos unto my Sansa Fuze 2GB player please guide me or answer me if there is a way to upload the videos or not please
You need to use the supplied Sansa Media Converter program to convert videos (and photos) to a form the Sansa can handle.
Aug 21, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze not Regestering Songs
The device only likes mp3's. Most other files don't show up.
Apr 13, 2010 | SanDisk Sansa e260 MP3 Player
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Aug 27, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze 2gb screen keeps saying not enough space and then turns off.
try plugging it into the computer back up all the music and delete some of the songs then try tuning it on again
Mar 20, 2009 | SanDisk Sansa Fuze MP3 Player
My mp3 player won't turn off!
Slide the power switch up for at least 10 seconds, this will reset the Fuze. After which you should be able to power on your Fuze normally.
Mar 18, 2009 | SanDisk Sansa Fuze MP3 Player
WINDOWS VISTA> RECOGNIZING SANSA FUZE
You need to upgrade the firmware to get it to work with Windows Vista
Jan 15, 2009 | SanDisk Sansa e250 MP3 Player
Sansa fuze 2gb is screen is white
If you just bought it, By all means return it!  Otherwise call sansa tech support.  The're rather good for tech suppport people.  If you bought an extended warranty, the place you bought it from should replace/repair it and you troubles will be over!
-Aptera
Nov 24, 2008 | SanDisk Sansa Fuze MP3 Player
Synchronize to continue your music subscription
first you must format the player using msc mode then after that retransfer the songs to the player. If you are receiving this message it means that the songs on the player have expired. This is normal if you download the songs off rhapsody, napster or any online music stores and if you have ripped songs iwht copy protect music on it if you ripped them using windows media player 10.
Dec 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
