Question about Systemax Arrival (036063) PC Desktop
No power The pc sounds as though it is running, but there is no light, nor communication with the monitor. The monitor says "power saving"... help
    Genius:
  • 2,785 Answers
Plz resit the ram, if the problem persits then you have to send the mother board for repair
Posted on Jul 01, 2008
Flatron L1732-s monitor is stuck in power saving mode. How can i fix this?
If you have a blinking power light and no picture or no power at all then the issue is not power save mode, it is a failure of the filter capacitors on the power supply board. The model monitor uses the AIP-0108 power board and when the filter capacitors go out you get the flashing power light. Here is a link to so information showing which capacitors will need to be replaced to rebuild the power supply board and get the unit back up and running.
http://www.ccl-la.com/catalog/product_info.php?products_id=246
And here is a picture of the power supply board with the capacitors circled in yellow.
Dec 06, 2012 | Computers & Internet
Power Supply Card crashed. Where i can I buy this card?
Does the PC light light up or does the PC make any kind of sounds at all? If not, it's probably the power supply. Power supplies are not cards though. You can get them about anywhere that carries PC hardware. Be sure you get a power supply that is suitable to the needs of your system.
Jan 01, 2010 | Soyo DYLM1986 Monitor
Problem w/Dell E176FPf monitor stuck in power save mode
Ok if it the monitor works fine on another unit discount it out of the equation as a monitor problem.
I would suspect the driver on the PC that delivers the problem, especially the video card.
. Check that the cable is also on tightly. remove it and even clean the pins and replug it .the plug on that PC may be dirty
You May need to replace the video card as the communication to the monitor is intermittent and that is why you get the amber light.
Open the box with power off. clean the card if it has a lot of dust on it ( most do and its always a shock) wipe it over ( BOTH SIDES) and then try to start it up as usual with the monitor connected to see if that fixed it ( sometimes works) if not get another card and replace it. Best I can offer without being there to help on the spot.
A new card should allow you access to install and configure it and these days they are pretty cheap to buy
Please rate this help to keep the service online
Aug 20, 2009 | Dell E153FP 15" LCD Monitor
Yellow power light on HP SR1420NX
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
tony
May 23, 2009 | HP Compaq Presario SR1420nx...
No power light and flickering screen
try to replace the cables first. if it that doesnt help then replace the monitor.
Sep 25, 2008 | Dell Dimension 2400 PC Desktop
Can't get LG desktop to communicate with monitor
connect the monitor to the PC and restart the computer. Make sure your keyboard doesn't have any stuck keys.
Dec 20, 2007 | LG Studioworks 700S 17" CRT Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Power light going to blinking amber
Sounds like a problem in the monitor's power supply. This will need component-level troubleshooting.
Jan 01, 2007 | Videoseven R17PS 17" LCD Monitor
Automatic sutdown monitor on runing pc
This is in your pc its the power savings in settings on your pc goto screen saver then powr settings try that. also is that movie or movi? the whole thing didnt make sense. maybe also integrated graghics issue
Nov 25, 2006 | SAMTRON 55V 15" CRT Monitor
Systemax Arrival (036063) PC Desktop Logo
29 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
