Home theater reciever volume level only makes large increases between -38 and -37.5 but doesn't make any audiable change again until -22
  • 682 Answers
Please bring a lubricat contact cleaner from radio shack near you and apply it with pipe over volume level while you are moving it forward and backward.-test with different media sources.
Posted on Jun 30, 2008
Coby 938 theater system volume
bagaimana caranya buka sandi hp expressmusic
Nov 23, 2013 | Coby DVD938 Theater System
The volume does not change when connected to my tv. The volume does change when i play dvd's. I have had it working before but since I have moved it does not. please help.
TV remote varies the TV amplifier drive - you are probably plugged into the "line" output of the TV (which is before the TV amplifier). Line out is a fixed level (your DVD preamplifier is controlled by the DVD remote).
Anyway, with the TV on - go to the home theater box and increase the volume there. Once you get that set, you should be able to use the Home theater remote to always control the volume for everything displayed on your TV (except channel changes)
Oct 14, 2009 | Audio Players & Recorders
Home theater hooked up volume sounds low
Check your different settings either in your t.v. or your amp. In your menu settings you can change your audio. Bass trebile etc. and even sometimes switching it from stereo,mono, dolby digital will increase your volume. Dolby digital is very quiet if your not running and exteranal amp system. so try changing it to stereo and your volume should increase.
Aug 31, 2009 | Panasonic Audio Players & Recorders
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
Audiovox VD1400HT Home Theatre System. Volume of radio too loud. If Radio is set at 7 it is very loud, but a DVD requires at least 25 before you can hear it.
that is normal. different sources have different output levels.. increase volume at dvd player will also increase volume of you home theater..
cheers!
Jul 11, 2009 | Audio Players & Recorders
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Dec 18, 2008 | RCA RT2760 System
Volume Control on my SCBT100 Blu-ray Home Theatre doesn't work.
Unplug the power and let it sit. Plug it back in and it should fix. Worked for me.
Oct 12, 2008 | Panasonic Home Theater System System
VOLUME CONTROL
Try to increase the speaker levels through setup. I had the same problem and I increased the speaker level from 0dB to +10dB, and seems like it is better now. Let me know how you make out.
Nov 29, 2007 | Onkyo HT-SR800 System
 Grubhead
Grubhead
