Question about Dryers
MDE 6200 AYW Maytag Atlantis broken baffle
Hello,  Is it hard to replace a broken baffle on this dryer?  Any ideas on how to take off the top, or does this need to be repaired from the front?  Thanks for your help.  Karen
  • Anonymous Nov 30, 2008
    i cant get top off
  • acrylman May 11, 2010
    what needs to be removed to check the fuses and heating element on a maytag atlantis? it is not getting hot.
  • 413 Answers
To lift the top and access baffle screws, proceed as follows;
1. Remove door hinge screws from cabinet. Door can remain in place.
2. Remove screws and plastic retainers opposite door hinge
3. Grasp each side of the top front panel and pull forward. Lift to remove panel
4. Remove lid retainer clamps from each front top corner.
5. Lift top to access drum baffle screws.
If you need further assistance, let me know
Posted on Jul 01, 2008
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag electric dryer model# MDE 4658 AYW does not dry my clothes (no heat) and the light no longer stays on when the dryer door is open. started happening after i turned all fuses off in the house. can...
I gotta assume you're joking since it looks like you're asking why the dryer isn't working when you've turned all the power off in your house.
If this is the case then the only way your dryer is going to function is if you bought it with the optional Maytag Cold Fusion power supply. Or you could turn the power back on...
Oct 30, 2013 | Maytag Dryers
Maytag Atlantis MDE 7400AYW is squeaking bad. Not sure, could it be a rear drum bearing grinding on the roller
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How do I get the top off maytag dryer, to get inside of it...Model # 6200
The complete Service manual is at the link below. The removal of the top is on page 5-2. Good Luck. Unplug unit before servicing.
Sep 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer access to the thermal sw
moz-screenshot-4.pngThe thermal limit mounts beside the heater element chamber and is held to it by the same screw that holds down the element.
The kit comes with 2 limits one fer gas the other fer electwic.
Sep 02, 2009 | Maytag Dryers
Dryer making banging noises
try this web site repair clinic .com expert advice and you can order parts right from them
Apr 06, 2009 | Dryers
Start button only lights up, does not start dryer
I finally fixed it !!!! 1st I replaced both thermal fuses and it still didn't work. So the next day I replaced the timer (start button) and voila !!!! it worked
Dec 14, 2008 | Maytag Atlantis MDE7657BY Electric Dryer
How do I get to the baffle on my maytag atlantis? It broke off and I ordered a new part
pop open top using screwdriver, rotate drum slowly by hand until broken baffle at 12:00 position remove two screws and reverse process.
Feb 13, 2008 | Dryers
Dryers Logo
906 people viewed this question
Top Dryers Experts
