Question about Freezers
Proline freezer door leaking
Hey,
about an hour ago my freezer door just started leaking water.
some of the shelves are frozen but some aren't?
the food is starting to defrost.
please help?
lisa
If this is not a frost free model It sounds like you have a freon leak. This is almost never worth fixing. Any fix would be temporary. You can never really trust it again.
If it is a frost free model it could be just stuck in defrost. Most commonly the defrost timer.
Posted on Jul 03, 2008
Have a upright freezer and the meat on the top shelf is thawed out but the rest of the food on the lower shelves are frozen. Is it a vent problem
Either the door seal is bad or the freezer has a refrigerant leak or a bad compressor. Best to have an appliance tech check it. It won't take him long to locate the issue.
Nov 04, 2017 | Freezers
Leaking a lot from water filter, which is inside and on roof of refrig.
Has the filter ever been frozen? that can cause it to crack. If not, it is probably going to be the filter head that has failed seals... Whirlpool Refrigerator Water Filter Housing WPW10238156
Mar 17, 2016 | Whirlpool WRF989SDAM 29 cu. ft. French...
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
Top is frozen lower shelves food is dethawing
One of two things is going on here, either the door is not closing properly (or some one left it open), check the seal all the way around especially at the bottom.
Or most likely you have a refrigerant (freon) leak that has left the charge low enough that you are unable to get it to cool throughout. A leak on this type of unit is usually in the evaporator in the corner where a weld was made. The evaporator is about $189.00, with refrigerant a new drier and supplies I bet it would run about $450.00 to repair.
Apr 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Lost vacumn, door popped open alarm on
If is the type of freezer where the shelves are also the evaporator(shelves are very cold and is normal to frost), the fact that only one shelf is iced would indicate the system is low on freon due to a leak. This would also explain the hot walls and compressor. It requires a service man to check the freon level and locate leak and recharge.
Sep 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
155 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
