Question about Mitsuba mv300 Camcorder
Need a manual
I have a problem with recording any data past 1 minute 7 seconds. I have the Mitsuba mv300 8.0 model. Can you please assist me with my problem or email me a manual. Thank you
  • 4 Answers
Mitsubausa.com has the manuals and you need to get a memory card. it only comes with 32meg . rite aid has them on sale all the time for like 5-10 bux for a gig.
Posted on Apr 20, 2009
Forget the manual, the product is trash. Don't spend 1 more dime for anything. A rip-off product, you got sucked into buying. Mitsuba needs to go back to china.
Posted on Aug 07, 2008
No matter the size of the chip 4GB or 16GB...I only get 10 minutes of recording time
What make and model camera? Ten minutes total recording time or ten minutes per clip?
There are two possible reasons why the clip length may be limited.
1) Some cameras limit the file size of any one video clip. Try reducing the resolution and see whether you can record longer.
2) In some parts of the world video cameras are taxed at a higher rate than still cameras. By limiting the length of a video clip, it's possible to avoid having a camera classified as a video camera.
For further details and limits, see your manual. If you require further assistance, please add a comment to this question and specify the make and model of your camera.
Dec 03, 2014 | Cameras
Mitsuba camrea dv9002 how to turn on the flashlight and i dont have the manual and the remote so please help me thank you
if it is like mine the flash is located on the left it looks like a lightening bolt and led light (for video) is located next to the menu button all of this is located on the side with the LCD screen
Jan 03, 2010 | Mitsuba DV9002 Flash Media Camcorder
How to switch from extended memory card
go to options>memory> there will be a setting that say "internal" or "external" click on external and then you'll be on the SD Card's memory
May 29, 2009 | Mitsuba Video Cameras
Need digital camera manual
mitsubausa.com. although your model isnt listed there are several cameras that look different but are really the same functionally.
Mar 28, 2009 | Mitsuba mv300 Camcorder
How do i REALLY erase on my olympus ws-300m?
Suggestion is to format the device to remove all unwanted data permanently.
1 While the recorder is stopped, press the MENU button for 1 second or longer. The menu opens
2 Press the + or – button to chooseSubmenu and then + button to “Format”.
3 Press the OK button. The “Cancel” indicator flashes.
4 Press the + button to choose “Start”.
5 Press the OK button. After the “Data Will Be Cleared” message is on for two seconds, “Cancel” will turn on.
6 Press the + button again to choose “Start”.
7 Press the OK button. Formatting begins and an indicator flashes
on the display.
“Format Done” displays when formatting ends
Dec 20, 2008 | Olympus WS-300M Digital Voice Recorder
Memory is full
You can only use a 2GB SD card. It is in the manual. I'm not sure on dvd.
Oct 24, 2008 | Mitsuba DV9002 Flash Media Camcorder
Need help finding users manual for my mitsuba dv55?
i need help with my mitsuba dv55f please.
Aug 14, 2008 | Mitsuba DV55 Camcorder
Recording stops within 10 minutes
Hi G-DyBiec
If the video capture automatically stops capturing at approximately 18 minutes (17 minutes and 55 seconds), then most likely the drive that is being capture to, is formated using Microsoft's FAT32 file system. Microsoft's FAT32 file system has a maxium file size of 4 GigaBytes (4 GB), which equates to a DV video clip of nearly 18 minutes. (18 minutes = 1080 seconds, @ a data rate of 3.6 MB/sec is approximately 4GB). So for hard drives that are formatted using FAT32, this behavior is normal. This is not a limitation of Studio..
To see what file system your hard drive uses do the following:
1. Right click on the Start button and choose Explore
2. Under My Computer, locate and highlight the drive you are capturing to
3. Right click and select Properites
4. On the General tab, towards the top, it will say "File System". It will be listed as either FAT32 or NTFS.
There are a few solutions if your drives are formatted using FAT32:
  1. Convert your FAT32 hard drive to NTFS *
  2. If you can copy any important data from this drive to other drives, it may be faster to re-format the FAT32 drive using the NTFS file system. **
  3. You can do multiple 18 minute captures and string them together in the Edit mode of Studio.
    • Since the first 18 minutes is already captured, rewind the camcorder or VCR to 5 - 10 seconds before the initial capture stopped (which can be edited out later in Studio).
    • Start a new capture to a new file name.
    • Repeat this process until all the desired video is captured from the tape.
    • After all the files have been captured, go to Edit and assemble the captured files from the Album to the timeline in the order you desire.
This is a manual method to workaround Microsoft's FAT32 file system and if this is too time intensive for your needs, then steps 1 and 2 above may be more suitable and should be considered.
* Note: If you need assistance with step 1 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "convert FAT32 to NTFS".
** Note: If you need assistance with step 2 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "how to format a drive in XP".
NOTE: Microsoft's NTFS file system is only supported on Windows 2000, Windows XP and Windows Vista. NTFS support a file size of 4 TB (terra bytes), which is larger than any current consumer hard drive capacity, so if NTFS is used, the capture file size will only be limited by the size of the hard drive.
Aug 13, 2008 | Pinnacle Dazzle DVD Recorder
Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Dec 08, 2007 | Panasonic DMR-E85H DVD Recorder
When in digital camcorder mode the camera only records 43 seconds how do i get it to record for a long period of time
throw the damn thing at the wall and next time u see the person who sells this POS punch them in the face for me
Jul 04, 2007 | Mitsuba DV500 Camcorder
Mitsuba mv300 Camcorder Logo
196 people viewed this question
Top Mitsuba Video Cameras Experts
prouddad_1
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
