When connecting HD DVD Player to Sony Received STR-DG520, we get sound but no picture. The HDMI wire is connected in the correct position.
The HDMI wire was malfunctioning at the TV end. Replaced with a high quality wire, works great.
Posted on Jul 01, 2008
Im having a hard time getting audio useing the hdmi ports on my sony str-dg520
The HDMI on this receiver is for video pass through only. It basically only serves the same purpose as an extension cord for an HDMI cable that's too short.
For audio you need to connect either a digital coax, an optical or composite cables.
Aug 25, 2010 | Sony STR-DG520 Receiver
Video but no audio
This receiver does not support audio via HDMI. You need to connect BD player via spdif cable. Use optical or coax depending on what does the BD player support - receiver supports both.
Dec 24, 2009 | Sony STR-DG520 Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
I connected my STR-DG520 5.1 to my TV Toshiba
In your str-dg520 menu you have the option to have the sound routed to your tv or out your stereo system. select which one you want.
Jul 12, 2009 | Sony STR-DG520 Receiver
Picture but no sound
Solved! After my continued troubleshooting, I discovered that I needed to enable digital audio out on the DVD player set up menu...I can hear clearly now too!
May 27, 2009 | Sony Electronics - Others
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Need unlock code for sony str-dg520 5.1
The HDMI inputs are pass through inputs only. The reciever cannot recieve any sound signals through the HDMI's. The reciever acts as a selector switch for the HDMI inputs only. Whatever input you have selected on the reciever is the one that is being sent through the output to your TV. The "unlock" display shows when there is no sound signal sent to the reciever. There is no code to unlock. This is the reciever's way of telling you that there is no sound being sent to it from that input. Since there is no sound being processed from the HDMI's, you need to hook up an additional audio cable from the device to the reciever (preferrably an optical cable). When the reciever recieves an audio signal, it will then "unlock". I know it is confusing. I had to look into this problem myself, so I'm happy to help. Higher end recievers will actually recieve and process sound signals from the HDMI's. When I bought this one I thought it was going to do the same. That's what I got for trying to save a couple bucks on the cheeper model! Although it is still a good reciever.
Dec 25, 2008 | Sony STR-DG520 Receiver
Sony STR-DG520
STRDG520 requires that the audio is from the digital optical or the digital coaxial to have sound. Just add digital audio from blue ray player to the amp and your good to go.
Nov 09, 2008 | Sony STR-DG520 Receiver
69 people viewed this question
 Grubhead
Grubhead
