Question about HP Pavilion dv1000 Notebook
DV1000 won't power up
Hi! My laptop won't power up when I press power button all lights come up and cpu fan spining a while, but screen is black, and no beeps. I've disasembled motherboard to check any visible damages but board is clear. I suspect open PL1 in power circuit, and maybe some short circuit capacitors. Any ideas I'm on wright way to resolve problem? Any other sugestions?
Please help me to fix my laptop.
Best Regards
Slav.
  • 5 more comments
  • novy74 Jun 30, 2008
    Thanks John.
    I've found shortcut on PD28 diode,( measured on board ) now I'll try to de-solder it and check. The SMD code on it is T25L. its located in power circut beside PQ118 voltage regulator. I let You know about results.
    It looks like common problem with DV1000.
    P.s. Used motherboard are too expensive - I'vesuccesfully fix already few laptops for my friends. Now I have problem with mine.
  • pvalentine Jul 09, 2008
    My HP dv1000 has the same problem, and so -- from searching Google -- do a zillion others'. Like many others, the fan quit on my dv1000 when quite new, so I learned how to disassemble it to fix my fan. You can find HP instructions at http://h10032.www1.hp.com/ctg/Manual/c00.... I say this because even if the fan is working well, the aluminum duct that transports the fan air over the chip gets clogged with dust. It is filled with a fine matrix of copper wire and there is just no effective way to clean it without disassembly. Take the duct off and run water through it. Now -- about this damned power up problem -- try this. Pull the display toward you and half-close the laptop till its only open about 3". Leave yourself just enough room to reach in and hit the power switch, HOLD the screen, pressing it slightly as if you were about to close it all the way, but not pressing enough to actually close it. Why? The display is screwed to the same inner frame as the mother board. Constantly Opening the screen flexes the frame and flexes the mother board... tiny cracks can appear in the board r the solder joints.. By holding it like this you are flexing it back the other way. Does it power up now? Mine did. But as soon as you open the display, it powers down again because the cracks in the board open up a fraction. Solutions: New mother board (of course)-- an expensive solution. A soldering iron and a steady hand (and a magnifying glass) -- this is only for the brave. Try some flat nylon washers under all the rear screw holes in the mother board. They bend the board up very slightly so it is concave. I was able to get mine to boot that way after re-assembly, but I'm really not confident about opening or closing the display any more than absolutely necessary. Still at least it is powered up and useable.
  • AbuHamid Jul 12, 2008
    HI, i have a similar problem as described here. I have shown it to an technician and he suggested an IC need to be changed but didn't disclosed which. Now the problem is he is demanding huge amount. would u pls me what is the price of a new motherboard or can you suggest how can i fix it myself.
  • Belinda Torres
    Belinda Torres Nov 12, 2008
    Hey um so is it has nothing to do with the motherboard cause my laptop screen doesn't turn on but i keep trying till it turns on but unfortunaly it has to restart becasuse of the updates so you think that might solve the problem or wat
  • RAYGOMEZ2008 Nov 26, 2008
    Hello. ! I have the same problem as Slav had, My laptop won't power up when I press power button all lights come up and cpu fan spining a while, but screen is black, and no beeps. Is the answer, is the answer have to replace PD28 Diode on the mother board..?
    Best Regards.
    Ray
  • RAYGOMEZ2008 Nov 27, 2008
    i couldnot find the pd 28 Diode, nor smc code T25L, and neither the PQ118 voltage regulator.
    Help please !
    Regards.
    Ray
  • Anonymous Feb 22, 2009
    DV1000 won't power up" problem,
    Problem Solver:
  • 12 Answers
Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
My laptop had the fan replaced - and the motherboard - while it was still under warranty. Makes me leery of buying an HP again already. Now the screen goes black. If I push the screen shut off switch quickly, it comes back on. Sometimes I have to do this a couple times before it stays on. Replaced the lCD inverter adn it wasn't that. Blonde is open to suggestions <sigh>
Posted on Sep 09, 2008
    Champion:
  • 258 Answers
I think you have dry joint on ***********-board.
Posted on Jul 12, 2008
  • 37 Answers
This sounds to me like a motherboard issue, you could try going over all connections with a multimeter to see if any are broken. I would suggest to try and replace the board that ill fix it.
- John
Posted on Jun 30, 2008
Fan not working powers up then off with black screen
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 09, 2012 | Toshiba Satellite L45-S7423 Notebook
HP 620 laptop shut down and won't start
Mar 24, 2012 | HP Computers & Internet
My 1501 Dell Inspiron turns on but I have a blank black screen. The only light that shows is the power light on the upper right side of the laptop.
Power getting to the laptop. Try first to see if this will give a screen image on an external monitor, listen for the sound of the cpu fan, hard drive and DVD rom drives clicking, see if the DVD rom drive will open if pressed.
Then remove battery and AC adaptor, press the power button for 30 secs, refit mains only and try this on mains supply (no battery)
If this fails to boot, check the light on the ac adaptor is a steady green, flashing green indicates power is not fully reaching the laptop (motherboard problems)
If it is steady and the LED power light on the laptop is steady, suspect the DC jack socket. If this feels loose or sloppy, it will need replacing, depending on the type fitted, it may be soldered onto the board, or a wired connector, which sometimes goes bad.
After that, I'd suggest that a capacitor has gone on the actual motherboard and you will need to strip the laptop to check it.
Jul 18, 2011 | Dell Inspiron 1501 Notebook
Hi i have a hp pavillion dv1000 laptop and the problem it has is that i can turn it on (lights turn on, fan runs) but the screen stays black and also the light that is below the screen (between the screen...
all DVxxxx have graphic chip problem. to confirm to say others are OK, remove the RAMs and turn on.
you can here memory beep error.its says others are ok.
now you can repair the main board( re-flow the chip or replace the chip) or if not need to replace the main board.
Dec 06, 2010 | Computers & Internet
I WAS HAVING PROBLEMS WITH OVER HEATING, NOW MY LAPTOP HAS CUT OUT AND WONT RE-START. WHEN YOU PRESS THE POWER BUTTON IT LIGHTS UP AND YOU CAN HEAR THE FAN OR SOMETHING BUT THE SCREEN STAYS BLANK. ALSO...
When a laptop overheats the CPU will shutdown, this is known as thermal overload. The laptop will not boot up until the CPU has cooled down. If this problem in not fixed then the CPU will eventually fail.
This problem is usually caused by a faulty fan or the fan and heat sink is clogged with dust.
Replace the fan if it does not spin freely and or remove the dust clogging the fan and heat sink.
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Screen doesn't come on immediately. Have to press
Checkout your poota power setup configs, just could a malfuction or wrong data entry
If you are talking "New" with a year, take back to point of purchsed with proof of purchase and give them the problem, you want to be online?
Nov 14, 2009 | HP Pavilion dv1000 Notebook
Hp Laptop problem
conect a external monitor to see if there is any image or if it is the same maybe the memory or prosesor damage
Dec 30, 2007 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
7,285 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
