Air Condition will not come on. We have tried to flip the breaker but no success. The fan on the air condition inside and on the outside is not turning.
  • 828 Answers
If you have one of those new digital thermostats try changing the battery. If your air conditioning is run through a central heating system the power must be on to the furnace. 24 volt control circuit gets its power from the furnace in this kind of case.
Posted on Jun 30, 2008
Compressor air condition wont turn on circut breaker goes out
open panel on outside will probably find something burned
Sep 08, 2014 | Heating & Cooling
All electric apt 5 year old fan wont turn off when air is off
Sound like bad mercury switch or time for a new thermostat would be my first guess, second guess would be that the condensing unit needs to be cleaned out side. it might be frozen up, that happens when it gstarts getting hot outside.
It might also just be as easy as flipping the breaker to the unit to allow it to reset and turning it back on. but if its still cooling and just wont shutt off, my guess would be thermostat or lose wire in there of.
If you dont have a maintenance guy you can call and it is too cool, try turning the breaker off at night until you can get it looked at.
May 29, 2012 | Heating & Cooling
The central air handler turns on but the outside compressor does not start. I have checked the breakers...they are on.
Check the condition of the contactor, Check the capacitor, If you have a multimeter, turn the power off and check the continuity of the compressor windings. You didn't say whether or not the outside fan is running. If it is then the contactor is working but look at the condition of the contacts.
Jun 20, 2010 | Heating & Cooling
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
No cool air but only fan working in central air condition
Check to see if outside unit is running. If it is check breaker,float switch inside. If everything is ok You have to call a Service Tech. There is only so far you can go. If you think the gas company had anything to do with it call them back and tell them it was working before you checked the gas. They could have left something off. Russ
Jul 23, 2009 | Heating & Cooling
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
My air condition is working but the fan is not turnig
fan has to turn for system to function properly turn off breaker see if fan turns if not bearings are shot if it does maybe fan motor bad or wiring issue! Good Luck!!!
Jun 24, 2009 | Goodman CKL36AR36 Air Conditioner
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Air condition unit will not cool and the coils freeze up in just a few min.
Is the inside fan running properly? Typically if the condensor outside is working, but the fan inside is not, the coils will freeze up quickly. For the system to work properly, you need to be blowing warmer air over the coils inside the house- that then brings the temp of the refrigerant in the coils back up, and the loop continues. If the fan inside is not working, check to make sure that the circuit breaker is not tripped.
Jul 06, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
278 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
