Question about Kenwood EZ500 CD/MP3/WMA Receiver
Loose Connections I had this professionally installed, yet the connections are loose. I'm not sure if this is faulty wiring or faulty hardware. When I push the unit in, the buttons work, but when I tree seeking for example, the buttons do not respond. Is this loose wiring or is there another problem with the EZ500?
  • 405 Answers
Good Day,
It's probably more likely it's a problem with the unit itself. If it was faulty wiring you would loose power intermittently and or have one or more speaker's cutting in and out.
Try contacting Kenwood to see if your warranty is valid.
Good Luck
Hope this helps
Posted on Jun 30, 2008
Engine stopped running, has no spark.
Hi, Ron if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
Good luck and have a nice day.
Nov 20, 2015 | Motorcycles
1990 Yamaha XJ 600 wiring diagram
Hi, John and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Motorcycle Wiring Diagrams
yamaha xj600 no spark
https://biker.ee/manuals/yamaha/Yamaha_XJ600S_1992_Service_Manual.pdf
https://www.partsfish.com/page/oem-parts-for-yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Dec 14, 2017 | 1990 Yamaha XJ 600
2000 dodge 4 dr neon,will not start. all lights are coming on. Lights go off leaving oil light on only. Oil is low but not that low.
Fuel tank empty
Battery discharged
Battery terminal connections loose or corroded
Leaking fuel injector(s) faulty fuel pump, pressure regulator
Broken or stripped timing belt
Ignition components damp or damaged
Worn, faulty or incorrectly gapped spark plugs
Broken, loose or disconnected wiring in the starting circuit
Broken, loose or disconnected wiring at the ignition coils or faulty coils
Defective crankshaft sensor or pcm
May 17, 2011 | Dodge Neon Cars & Trucks
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Have changed out the Alternator and battery with new ones. Battery will still not stay charged. Thought it may be a Voltage Regulator issue is that the only other thing it could be?
MAKE SURE YOUR BATTERY CABLES ARE CLEAN AND TIGHT.MAKE SURE YOU ARE GETTING GOOD GROUND AT NEGATIVE BATTERY CABLE.IF BATTERY CABLES VERY OLD REPLACE THEM.IF ALL IS GOOD ALTERNATOR HAS LOOSE B+ WIRE AND FIELD WIRES CONNECTIONS MAKE SURE NONE OF WIRES DAMAGED AND ALTERNATOR DRIVE BELT NOT LOOSE SLIPPING.IF ALL GOOD YOUR ALTERNATOR HAS THE WRONG AMP AMPS TOO LOW HAVE WRONG ALTERNATOR. OR YOU HAVE FAULTY ALTERNATOR.
Aug 22, 2010 | GMC Safari Cars & Trucks
The black wire on the lower heater lug has melted off twice. Is this because of the faulty hi limit thermostat or the cycling thermostat?
For a wire or terminal to burn off is usually caused by a bad , or loose or dirty connection or terminal end.
It is not caused by a faulty component.
Make sure all connections are clean , firmly fixed and secured.
Mar 07, 2010 | Maytag Dryers
Installed aftermarket stero in GMC Z71, is you hit a bump the stero goes off
double check all your wiring and make sure all connections are tight. if there's an inline fuse holder, make sure it isnt loose. and make sure your grounding point is tight and clean. also check the fuses and wiring under the dash. if everything checks out, you've got yourself a faulty stereo.
Feb 17, 2010 | Car Audio & Video
Not heating up, flashing light
It sounds like you have a loose wire, check your plug to make sure the wire connections are sound. The loose connection may be where the wire enters the iron its self. For saftey I would have this repaired by a professional or have it replaced.
Dec 04, 2009 | Tefal Irons
My car wont' start i think lead on starter may be disconnected where can I get a free online diagram
Tighten you connections, on the battery, and on the starter. Make sure all ground connections are secure, if you find any loose tighten them.
The clicking sound means no power to starter, or too much resistance in circuit (loose connections, "torn" wires, corroded connections) Clicking sounds could also be if you connected the starter wrong, but if it ran once it should run again. So, check all the wiring, make sure nothing is loose.
Starter wiring is rather simple :
Battery to Starter "Bat." terminal on solenoid from there solenoid has a wire going to the starter itself, and the starter grounds through mounting bolts to the engine.
PS - If your battery nodes/connections are dirty and corroded clean them, give them a good scrubbing and then reconnect securely.
May 10, 2009 | Ford Escort Cars & Trucks
My dvd decoder is not properly installed
Check your connections for loose wires.If it is correctly installed it should show up as new hardware recognised on startup.
Aug 14, 2008 | Lite On Computers & Internet
Kenwood EZ500 CD/MP3/WMA Receiver Logo
120 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
