Question about HP 1040 Plain Paper Inkjet Fax
HP 1040 Fax # rings busy continually and when I try to redail it says no answer from remote. What does this mean.
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
If you dial the number on a regular phon e does it go through or is it busy? can you fax to a different # ?
Posted on Jul 15, 2008
Hi. When my house phone rings more than three times my fax machine trys to answer the phone making conversations inpossible. How do i get my fax hp1040 to answer only my fax's?
The fax is set to answer on the 4th ring. Change it to answer on say... 6 rings.It cannot differentiate the call before it's picked up ... it just answers at at set number of rings
Apr 01, 2011 | HP 1040 Plain Paper Inkjet Fax
HP CM 2320 nf MFP keeps saying...... fax line is busy....
I had this problem as well - try the following:
1) Change your rings-to-answer from the default of "1" to "3". This is found in the basic fax setup on the control panel of the printer itself.
This solved the problem for receiving faxes that I was having when testing fax reception by the HP 2320nf from an dedicated fax. The remote fax would fail after repeated rings with a "BUSY" indication in the fax error report it printed. "BUSY" equals either actually "busy" or also it can mean "no answer".
What I found on the 2320nf end was that it had detected an inbound fax but never answered it. The color LCD on it had "fax received" but the device itself appeared hung.
Hope this helps.
Mar 30, 2011 | HP Laserjet CM2320nf All-In-One Color...
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
I am having problems receiving a fax.
Check the number of rings your fax machine is set to. Chances are, the answering machine is set up for 4 rings and the fax machine is set up for 6. If this is the case, change the number of rings on your fax machine to 2 or 3 rings to ensure an incoming fax will go directily to the fax machine. If the fax doesn't recognize the call as a fax, it will go through to the answering machine.
Jul 17, 2009 | HP 1040 Plain Paper Inkjet Fax
How to set hp1040 fax to work with aout answering
If you are using the same phone line as your fax, you can start by connecting the answering machine on Line2 or 2-Ext at the back of the fax. Set the fax to answer on two rings higher than the Answering Machine. (for example: if answering maching is 4 rings, fax is 6 rings)
And then, turn on the auto answer.
Mar 22, 2009 | HP 1040 Plain Paper Inkjet Fax
Fax is not Receiving
Unplug the power cord for 10 seconds.
Do you have DSL or any other kind of digital phone service?
Oct 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Machine does not receive faxes
It the funky line DSL?
Fax machines are designed to be on a dedicated ANALOG phone line. Sorry
can hp 1040 fax transfer printed copies to hp pavillion note pad
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
HP 1040 Plain Paper Inkjet Fax Logo
73 people viewed this question
Ben Johnson
