Question about Vacuums
After replacing the flat bet and v belt on my Hoover model U6433-900; serial No. 12300043057, purchased June 23, 2004, the brush roller still does not turn when I release the foot lever to vaccuum.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=725351
Generic problem for all Vacuums
Posted by mahammons on Jun 30, 2008
After replacing the flat bet and v belt on my Hoover model U6433-900; serial No. 12300043057, purchased June 23, 2004, the brush roller still does not turn when I release the foot lever to vacuum.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can think of if that the brushroll may have to be rebuilt and new bearings need to be installed on each end. If unrebuildable, then you need to purchase a new one but most are rebuildable. The other thing is to check the motor pulley to see if that spins freely as well. If you have a problem or other questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 01, 2008
Hoover F5915-900 brushes will not rotate
The motor rotates the bar. My guess would be that the rubber belt that goes from the motor to the belt has fallen off the bar , broke, or the bar is not seated properly. GOOD LUCK FRIEND.
Nov 13, 2014 | Vacuums
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
I'm getting no suction and the brushes are not rotating
Hello! If you are using the cleaner on carpet, it is necessary for the brushes to rotate to assist the motor with maximum pick up. If your brushes are not spinning check the belt to make sure it isn't broken or stretched. The belt will need replacing about once a year. Below are steps for checking the belt on your U5399-900.
1. Place handle in low position and turn cleaner over so bottom side is up.
2. Remove the 4 screws. Lift off bottom plate.
3. Inspect the belt for rips and tears. If it is damaged in any way, broken or stretched replace the belt
This unit takes belt 38528033. Be sure you replace belt with genuine Hoover parts. Here is a link where you may go to order a replacement belt.
Service Center Locator
Hope this helps!
Jun 05, 2014 | Hoover U5399-900 WindTunnel Lite Upright...
The brushes on my Hoover Steamvac Widepath LS SpinScrub model # F6040 900 are not spinning. What should I do to get the brushes spinning again?
On those models the brushes are turned by suction.
1. Check the lower tank to be sure its completely closed and sealed.
2. Check the lower tank to be sure the tools filler plate is in place (if you used the tools recently)
3. If both 1&2 ok, manually turn the brushes, if they do not turn freely you may have a stuck turbine or bad brush block.
4. Take the brush block out by releasing the tabs on each corner being careful not to break them.
5. Place a large flat blade screwdriver in the square drive hole that drives the brushes under the machine. Gently turn. It should turn slowly with some resistance. If it turns slowly it is ok. If it turns with no resistance it may be bad as well. If it will not you may be able to break it loose with some even pressure being careful not to strip the hole. If it will not turn or makes a lot of noise replace the Turbine assembly.
6. If the brush block has a broken drive shaft or will not turn replace the brush block.
Here is what that brush block should look like.
http://www.vacuummedic.com/product.php?id=206
Good Luck!
Aug 21, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Replace belt on hoover vacuum U4655
Turn the machine over and remove the 4 screws which hold the cover on the brush. Remove the cover and brush roller. Remove old belt. Slide new belt over the motor pulley, first. Then slide roller through new belt (if self propelled model, slide roller through the small belt, also) and slide brush roller into slots on housing (note: slots are different, match roller sides to correct slot.)
Oct 22, 2011 | Hoover Vacuums
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roll wont turn
Might be that the the idler wheel is stuck and not engaging the V belt. If you look down just past the V belt you will see a black roller, it needs to be against the belt. It is either stuck or the asm. is broken.
Apr 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
