Question about Kenmore Dryers
Stains from dryer
My dryer has started leaving stains on my clothes, almost looks like rust.
    Genius:
  • 1,028 Answers
Rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Posted on Jul 01, 2008
My dryer is leaving rust stains on my clothes
you needto replace your dry drum .
Sep 30, 2015 | GE Dryers
Washer leaves stains on clothing
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Aug 11, 2008 | Whirlpool Washing Machines
Im gettin 1/2 inch to 2 inch rust like streaks on my light clothing after drying. I took a wet white cloth and wiped them along the felt seals at the front and back of the dryer and got the same staining....
You are absolutely correct. Replacing the felt seals will definitely solve the problem and you have to look forward to replacing the same in another 4 years. The seals are sold as pair as you need to replace both but they are cheap and easy to replace. The only hard part is getting to the seals as you need to get the top and the front panels then the drum itself to get to the rear seal.
Aug 14, 2011 | Dryers
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer is leaving discolored stains on my clothes. it shows up most prominently on whites, they almost look like shadow stains, but they're getting worse. what is causing this?
If this is a top load machine, you have a bad tub bearing. This will cause your clothes to have what looks like rust stains on them. It's actually grease form the bearing. It can be replaced and I would rate it a 6 on a scale of 1 to 10, 10 being the hardest.
Please rate solution
Sep 02, 2009 | Washing Machines
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Clothes dryer
It could be rust stains coming from the tub of the dryer during the drying cycle. The only concern is that rust stains are usually brown streaks on the clothes. I'd check the to make sure there are no rust stains on the tub, check the seal of the door to make sure its still in good condition. The last possibilty could be a good cleaning of the dryer (removing lint from the lint screen compartment and the tub of the dryer).
A schematic of your dryer can be found on www3.sears.com and should show how to get into your lint screen compartment and your tub.
Feb 07, 2008 | Zanussi TD4100W Electric Dryer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Dryers Logo
422 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
