Question about Microsoft Wheel Mouse Optical PS/2 USB Keyboard
Mouse Problems I have the microsoft Wheel Mouse Optical with the ps/2 compatible whatever thing. Anyways I have had this mouse for a little over a year and it has been working fine until recently. When i enter a game called Counter-Strike at random points it will freeze and lock up in a position for 15sec or so then come back for a minute then freeze again.It used to work fine in that game but now it has this problem.I have only noticed it once not working outside the game.Occasionally i hear the usb noise when it is unplugged then plugged back in even though i never touched the plug-in area. Any Suggestions? thankyou,
  • hspontaneous Oct 03, 2008
    I have the same problem . When I unplug and plug the mouse things get better for few seconds/minutes and mouse stops reacting again. Tried a different USB port and a different mouse - still the same .
    This problem started a monthe and a half ago .
    A.A.
    Scholar:
  • 51 Answers
It's possible that your connector isn't properly seated and/or getting a good connection and the large amount of mouse movement that games like Counter-Strike require could be causing it to unseat and reseat sporadically. If your model is a USB unplug and plug it back in "firmly". also you can try using a different USB port.
The reason it's taking 10-15 seconds is because windows is uninstalling and reinstalling the mouse in your hardware profile every time it loses connection. Since this is a fairly memory intensive operation as far as windows goes and you're already playing a video game (which are notorious for using large amounts of RAM and CPU time) that's just how long it's taking.
If unplugging and reinserting the cable doesn't work, your best solution would most likely be to simply go out and buy another mouse.
Posted on Jun 30, 2008
Every mouse i tried to plug to my laptop does not work
Click on Control Panel and then Add a Device. Try adding your mouse as a generic HID Compliant mouse. Windows will install a driver. Then go to the download page Microsoft Software Downloads
and find the appropriate driver for you mouse, download it and install.
Apr 20, 2011 | Microsoft Wheel Mouse Optical PS/2 USB...
My left and right buttons on my wheel mouse seem to be switched it isa microsoft optical usb and ps/2 compatible 5V 100ma
OK what you do is you head to the control panel for the mouse her you should have and option to envert the mouse buttons double clich sensitivity click apply on the window and it will save your changes.
Did this help you or Do you need more imfo?
Oct 20, 2009 | Microsoft Wheel Mouse Optical PS/2 USB...
The exact same problem
Roll back the mouse driver:
1. Right-click [My Computer]
2. Select [Manage]
3. Select [Device Manager]
4. Locate your mouse on the right windows and press the +Mice ...
5. Right-click HID - Compliant mouse ( or whatever)
6. click [Properties]
7. In the "Driver" tab, Select [Roll Back Driver]
Mouse is now free from Microsoft trap....
Sep 19, 2009 | Microsoft Wheel Mouse Optical PS/2 USB...
Mouse wheel scrolling has changed
try control panel settings for your mouse
Apr 03, 2009 | Computers & Internet
Microsoft Optical 1.1A Wheel Mouse Optical - USB, PS/2 (D66-00034)
Hi again,
Appreciate the direct "Ask Me" and the repeat use of FixYa.
Interesting concern, should be pretty straightforward. Anyways, pls try to:
  • update/re-install the driver from Microsoft Download page;
  • alternately, disable the "Allow the computer to turn off..." in the Power Management tab of the USB Root Hub Properties in your Device Manager.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you again for using FixYa.
Oct 10, 2008 | Microsoft Wireless Optical Mouse
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Turning Off Pointer Acceleration
Go to Control Panel and click on the Mouse icon. You should be able to decrease the speed by dragging the speed bar to the left. Hope this helps. bud
Jul 19, 2008 | Microsoft Wheel Mouse Optical PS/2 USB...
Microsoft optical mouse
no its not worh repairing if you are able to get you hands on the mini switches and want to solder it on then it might be a little cheaper.... you can also try opening the mouse cover and cleaning out the switch located under the pedal
May 28, 2008 | Microsoft Wheel Mouse Optical PS/2 USB...
Open Questions:
Microsoft Wheel Mouse Optical PS/2 USB Keyboard Logo
308 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
