Question about Samsung Office Equipment & Supplies
Hi I am just settung up a Samsung CLP 300 printer. I can print off the settings, so I know the toner cartridges etc are installed ok. I connect the USB cable to my Dell laptop (there is only 1 slot on the printer for the cable, so can't go wrong there). I try to run the installation software for a local printer connection and get the message "the device is not switched on or connected." There must be a simple answer since the device is both on, and connected through a short USB cable to the laptop. I have tried all 3 USB slots on the laptop with the same result. Help!
    Genius:
  • 2,785 Answers
Plz do not connect the device before the software ask for it.
Posted on Jul 01, 2008
Hi. My Samsung CLP 300 Laser is playing up. It
The problem you are experiencing is a common problem with this printer. What happens is over time as the printer is used, toner or developer builds up a film on the developer blades. The developer blades meter the amount of toner that the printer puts on the paper to make the image. As the film builds up, less and less toner makes it to the page causing the image to become faint. The black developer blade probally is clogged.
This can be fixed two ways. The easiest and most expensive is to buy a new imaging unit for about $100+. The second is to disassemble your imaging unit and clean the developer blade(s). This can be done in about 30 minutes. I have posted instructions in my Tips section.
Feb 18, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
New toner cartridge but will not print
To get exact error. Please install samsung Smart panel software.
The error may not be from toner . May be toner or Compatibility issue.
Best Regards
Nov 27, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
May 05, 2009 | Samsung CLP 300 Laser Printer
Smasung clp 300 will not print in blk
check if your toner cartridge(s) is moving the toner supply spiral,
you can see it in hole where toner leaving bottle. (you must push the
valve in cylindrical output of cartridge inside about 20mm).
When you rotate anti-clockwise gear of cartridge, the spiral inside must rotate too.
My original toner has this broken and print was light.
You can have also bad developer unit, blade, or contacts, or printer electronic board.
Mar 07, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300
take the toner cartridge out shake it abit and install it again... try and print
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Samaung 300 clp series
Are the toner cartridges genuine? If not then they may contain inferior toner. If your cartridges are genuine then you will need to change the setting of your printer in the computer to try and get a higher resolution
Jan 03, 2009 | Samsung CLP series CLP 300 Up to 16 ppm...
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
