Repair to hole in washer plastic drum.
I've been out to a washer that the owner had stripped because it was leaking. After refitting the hoses properly and testing, it was actually leaking from an 8mm hole pierced in the bottom of the plastic outer drum.
My question is - What would be the best method to repair a small hole in this plastic, that can withstand boil washes and immersion for around 2+ years use.
- Mechanical, epoxy , silicone , combination of methods?
Thanks.
  • Desphsewife Oct 27, 2008
    We have the same problem! My husband left a screw in his pants pocket which made a hole in our plastic washer drum. Is there a particular plastic epoxy you recommend? The guy at our local hardware store said "your guess is as good as mine."
  • Richard Perkins
    Richard Perkins Nov 05, 2008
    I used a flexible polystyrene based epoxy filler - the type used for car bodies. NOTE! - It MUST be the flexible version, as this accomodates for temperature changes.
    Make a plug by overfilling on the inside of the drum - so it cannot get pushed out again, and when set (only 20 mins or so ) add a layer of silicone sealant to the inside. This rubber will fill any pinholes, and is very flexible and will act as a waterproofer for the repair. No problems so far in 3 months use.
  • 3 Answers
I had the same issue, I got some liquied fiberglass from out local car shop, striped down the washer and split the drum so I could get the the inside and out, I rubed down the hole with soem ruff sand paper to make a good key then applyed the fiberglass, waited for 3 hours to make sure it was good, put it backtogether and all is done been great now for last 3 years.
Colin
Posted on Sep 28, 2010
  • 3 Answers
The easyest way to fix a hole in most things if there is room is to drill out the hole to the nearest size bolt. then using stainless steal bolt normally 6mm works good with two stainless penny washers two tap rubber washers and a 6mm locking nut . method is drill hole when i fixed mine i use 6mm drill then get bolt feed on 1 penny washer then 1 rubber washer,feed bolt through inside of drum were it comes trough to outside then put on other rubber washer then the other penny washer then finally the locking nut tighten every thing up instant fix last longer than the thing it self and most glues i think only thing glues are good a sticking is fingers lol
Posted on May 31, 2009
I used instant gasket for sealing coolant leaks. The silicone base is flexible, can adjust to temperatures and it resistant to corrosive agents such as coolant so I guess detergent should be good.
I pressed a good amount inside so when it expand as it hardens it will form a plug inside and then when dried I applied another coat.
All good so far..
Posted on Aug 24, 2013
    Champion:
  • 254 Answers
If you find a good plasticizing epoxy it should work great for this most plastic epoxies can withstand temperatures up to 500 degrees F. I dont see the hot water supply feeding the machine getting any warmer than this. Another option would be to find someone with a plastic fusion and filler welder and just weld the hole shut with a base material.
Hope this helps Ya
Posted on Jul 03, 2008
My Maytag Ensignia washer is leaking water from the pump area of the washer. I've eliminated the drain hose and I've traced the leak up to the area of the plastic casing around what looks to be the...
Look for broken plastic casing of the pump. A hairline crack would also leak water. Check for proper fitting of flexible hoses to & from pump. Another thing is to check for loose filter cap. A loose filter cap or broken O ring of the filter cap can leak water.
Sep 18, 2011 | Washing Machines
It is blocked so the water cant drain
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Refit and test.
Dec 12, 2010 | Creda W120VW Front Load Washer
Machine will not empty
Remove lower rear cover of washer.
Remove large black hose from bottom of drum.and remove and clean plastic filter inside hose.
Refit and test.
May 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error f0-05 showing during cycle
Error code F05 means water level switch is stuck on full.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Refit and test.
Mar 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hole in door gasket of a Hotpoint 9901w washer dryer.
It is quite involved to change the seal, as requires a partial strip down, if the hole is not very big, then you can do a fairly good repair using a bicycle punture repair kit..
Remove the plastic clip that holds the clamp ring on the front of the washer seal at the top, remove the clamp ring, take note how it is fitted, then pull seal off front of washer, and fit patch on underside of seal, refit seal and clamp,and job done!!!!
Plz rate my solution.
Thanks.
Jan 25, 2009 | Washing Machines
Water is leaking from soap dispenser only at beginning of cycle
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Got lots of fluff under the drum
You will find the filter at the rear of washer..
Remove rear lower panel, on right you will see a large black hose that goes to the bottom of drum,
Undo clip that secures hose, and remove hose, be careful as there will be some water run out.
Remove plastic filter and ball inside hose, and clean filter, replace and fit hose back onto tub, making sure it is on properly.
Test for leaks before you refit rear panel back on.
You may have to repeat the process more than once if there is a lot of fluff present.
Thanks
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Water pouring out from soap tray !!!
hi Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Sep 13, 2008 | Washing Machines
Washing Machines Logo
6,609 people viewed this question
Top Washing Machines Experts
