Question about Cuisinart DCC-2000
Programming the current time on clock..the auto start etc
  • 8,596 Answers
Turn the function dial to Clock, then press and hold the HR button for a few seconds. Do the same with the minutes button. Then turn the function knob to a setting other than Clock. Voila!
Posted on Mar 20, 2009
I have the timer programmed but what mode should it be in Off, Auto or Random? I had it in Auto but the timer did not start at 10 am as programmed! Help!
HB88RC is discontinued timer, replaced by 2-outlet HB800RCL or 1-outlet HB800RCH.
Timer functions should work in AUTO.
Try resetting timer by removing AA battery, reinstall fresh battery, and then reprogram timer.
When programming is finished, press clock button and timer should be in AUTO mode and current time displayed.
If you want to change mode, then press mode button. When exiting mode, press clock button and timer should be back in AUTO mode.
If functionality does not restore, then timer has gone bad.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://waterheatertimer.org/pdf/hb88rc.pdf
Jul 05, 2011 | Intermatic HB88RC Outdoor Timer
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
I am trying to st the timer to turn on at 5PM and turn off at 11PM.
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 5pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
I DON'T KNOW HOW TO PROGRAM THE TIMER I'VE LOST THE MANUAL. I NEED TO SET IT MON- SUN FROM 7PM TO 12PM IT SHOWS: 1 ON THIS IS WHERE I HIT HOUR & PUT 7:00PM THEN I HIT PROGRAM IT SAYS 1 OFF I HIT...
Here's HB88RC programming from the top:
Remove batrery from back of timer to reset timer and clear everything.
Re-install AA battery in timer so display will show, and you can program
Set clock:
Program timer:
This is Event1 ON
Press Hour button until 7pm shows >> this is event1 ON
This is Event1 ON
Press Hour button until 12pm displays >> this is event1 OFF
Add a comment any time.
A lot of folks have written in about this timer going bad and they have been unable to program the timer. Of course most timers work perfectly fine.
For GE- 15117, Mode acts as a controller called "an On or Off override..." "or sets events to Automatic or random" Random = a +/- program shift (that's understandable). You'd think...
I cannot make precise sense of your question.
However I agree, the manual for GE 17117 is not clear.
1) A number of folks are writing in about this particular timer, with same MODE problem as you.
Some folks, the timer skips over auto.
Some folks the timer just doesn't come on.
Facts are facts, some timers are busted on arrival.
But let's look at the problem from three different directions and see if it helps:
2) Steps from manual:
When you finish programming, press clock button to return to current time.
Next set MODE.
Press MODE button and timer enters override ON-OFF. Override reverses whatever program is operating at that moment.
Press MODE button again and timer enters RDM random mode, and lights turn on-off randomly.
Press MODE button again and timer enters AUTO >>> auto is correct setting that lets programs run.
Here's the trick: after setting MODE to auto, press clock button again and current time displays.
If timer will not perform these steps, then timer is suspect
If timer performs these steps, but programs won't work, the timer is suspect or programming is suspect.
3) Check programming for conflicts and overlaps that cause timer not to function 'as expected.'
Some timers skip over conflicting programs, some timers simply stay on, others stay off.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
Example of conflict is event1 ON at 7am TU > but event1 OFF at 11pm All-days. Both event1 ON and OFF events must have consistent days >>> so change TU to All-days.
Another example is event1 ON 7am OFF 11pm TU >> but event2 says opposite, or has overlapping times.
I suggest folks make a schedule of programs before starting.
To review and change programs, start with current time showing in display: Press PROG button and scroll through event1 ON, event1 OFF, event2 ON, event2 OFF, etc.
Write down the events and make a chart.
Look for overlaps, and check for days of operation, and make sure each event ON has corresponding event OFF
4) If events are correct, and timer MODE button functions, but timer still doesn't work, the final suspect before calling the timer busted, is circuit problem. Use circuit analyzer on receptacle. Or plug timer into receptacle on different breaker and see if problem persists.
Dec 11, 2010 | GE Hardware & Accessories
Have the timer set on Auto but lights are not on during the ON period. Also do I need to set times for all 7 periods?
No, you do not need to set all 7 timer events.
When event1 ON and event1 OFF are set, press CLOCK button to exit programming and save programs. Or press PROGRAM button and move to event2 ON and event2 OFF. Exit programming any time by pressing clock button.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
That being said, if events conflict with each other, timer will not operate.
For example event1 ON FR at 7pm and event1 OFF all-days at 11pm.
The days have to match for on-off times.
Another example event1 ON FR at 7pm and event1 OFF FR 11pm, but event2 ON all days 8pm event2 OFF all days 10pm. This overlap will cause timer to skip programs.
If timer is being used in random mode, timer programs cannot be closer than 1/2 hour apart.
When programming is done, press clock button to display current time.
Timer should be ready to go.
Manual is fuzzy at this point, and does not specifically say, but it appears that you only press MODE button when you want to set another mode beside auto.
I e-mailed Intermatic last week about this unclear spot because several folks are writing in about this timer not going into correct MODE after programs are set.
MODE must be set to automatic
Press MODE button once for manual override function
Press MODE again and RDM displays for random >> this is for lights turning on randomly when on vacation.
Press MODE button third time, and AUTO shows on display >> you want timer in AUTO for timer programs to operate.
Here's the trick ... after setting MODE to auto, press clock button to display current time
If timer will not enter AUTO, then timer is defective.
If Intermatic sends response that is pertinent to your question, I will post again on this thread.
Add a comment any time, and I will respond.
Dec 10, 2010 | Intermatic HB88RC - 7-Day Programmable...
I can't figure out how to set my Utilitech model #TE06WHBL 2 outlet timer
Utilitec is packaging two different Woods brand timers under that number.
TD1300 with 4 buttons on top row and 59377 with 3 buttons on top row
See woods timer and manual page to help identify your product:
Here are instructions for timer with 3 buttons on top row
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Press reset button with paper clip to reset timer
To set current time:
Press and hold clock button
Press day until black triangle lines up with current day symbols that are printed on timer.
Press Hour until current hour and am pm show
Press min until current minutes show
Release clock button.
Programming:
Write out programming schedule before starting to avoid conflicts in programming that will stop timer from functioning
Set up to 8 programs
program1 program2 ... program8
Step1) Set program1 ON time > with day hour and minute
Step2) Set program1 OFF time > with day hour and minute (choose same days as ON)
Step3) Set program2 ON time, etc
How to program:
Step1) Press PROG button until ON and 1 appear in display
This is program1 ON
Press day button to choose day or blocks of days you want program1 to turn ON
Press hour to choose hour for program1 ON
Press min to choose minute for program1 ON
Step2) Press PROG button until OFF and 1 appear on display
This is program1 OFF
Press day button to choose day or blocks of days you want program1 to turn OFF
Press hour to choose hour for program1 OFF
Press min to choose minute for program1 OFF
Step3) Set program2 thru program8
Press PROG button until ON and 2 appear on display
This is program2 ON
repeat steps to set up to 8 programs.
When programming is complete, press clock button and current time shows
Press manual override button until black triangle lines up with AUTO that is printed on timer.
Dec 07, 2010 | Hardware & Accessories
I caNT SEEM TO PROGRAM OR CHANGE THE TIME . HOW DO I DO IT
Page showing Woods timers and models:
Add a comment with specific model number and I will help.
Instructions below are for Woods 59203 24-hour digital timer:
Plug timer in until battery is recharged.
If display will not show, then timer battery is dead and needs to be recharged, or timer may be broken.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Nov 27, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I bought a Utilitech #0155671 and the instructions are difficult to follow can someone help by providing step by step guide starting with setting of the clock basically it is to techinical for me to...
Programming:
How to program:
This is program1 ON
This is program2 ON
Nov 14, 2010 | Hardware & Accessories
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
245 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
