The printer that I have (HP Photosmart Plus B209) will not print today! It keeps sending the message: Oxc19a0022
Below that message it states:
"Please turn the printer OFF and then ON."
I have turned the printer OFF and then ON about 15 times with no change! Still the same message - still not printing!!! I am frustrated!
Does your printer have a CD disk to install it on your computer. Go into My Computer and delete or remove everything that is associated with that printer then reinstall using your disk. That will reset it back to factory installation.
The error oxc19a0022
is mostly occurred in HP printers. To solve the error code oxc19a0022,Follow the given steps
Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
Remove the cartridges from the printer
Wait for the 'Insert Cartridges' message to display on the control panel
Disconnect the power from the back of the printer
Now wait 60 seconds
Now reconnect the power If the product does not automatically turn on, press the Power button
Reinsert the cartridges, and then close any open doors on the printer.
If you receive a prompt to print a calibration page.Print it
Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove. But if u face still this error then printer service required.In that condition best option is to Contact HP Service Provider
I hope this solution helps you Thank you for using FixYa
Try resetting the printer a second time. If you have done this step, unfortunately, you either need a replacement print head or the printer needs service.
Print heads are not returnable if a new one doesn't solve the problem.
You can use the program that comes with the printer. Its called HP Solution Center. There you can view your printers status, etc.. In addition you can choose to copy, scan or print files.
A wide range of problems are addressed in the following solution from HP. From what you have stated, try Solution 2, Step 3 - "Determine whether the printer is paused or offline."
