Question about Fisher and Paykel Washing Machines
Will not start while plugged in. repair guy says needs two new boards....is there a fuse i need to check on this machine....washer
    Genius:
  • 1,028 Answers
If a top load remove the plugs on top front corners remove screws lift top remove screws top corners of front pull front away ..on inside at bottom small button on hilimit tstat press and reassemble try again if not working repair guy may be right but have my doubts about both bds
Posted on Jul 01, 2008
Stat button
see this steps and fix it. GOD BLESS YOU
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Enter your model number to see parts for your washing machine.
Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Jul 21, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine wont turn on
see this instructions and fix it. God bless you
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
Jul 21, 2013 | Washing Machines
Isnt gettin power but cord work outlet works
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you3958e768-3a49-432b-8096-35c2e90be05f.gifbf55c0bf-2b61-4cdd-8831-a6dc82140f68.jpg
May 23, 2013 | Maytag MAV7600 Top Load Washer
Maytag washer mav7600aww doesnt get power
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you938a0a02-c262-417d-a982-3a081cef735f.jpg2b39c595-65d9-457a-8ed4-d3bb6d2facd8.giff6783cbc-852f-47b4-98d7-bd94a664080e.gif
May 23, 2013 | Washing Machines
Simpson swt802sa
he most common parts or causes, ordered by the likelihood of fixing the symptom.
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you11c63312-8cb1-4484-928d-4b5c239b0f35.gif243403b0-440d-4f8b-b217-fdfd20c409ef.jpegc0210118-4dbd-4ea4-980b-16577c9769fb.gif
AEG Lavamat Turbo 12710 update. Machine is AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts t
test the following steps and fix it. God bless you
Jan 23, 2013 | AEG Lavamat 12710 Front Load Washer /...
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The drain/circulation pump quit on my fisher paykel gwl11
Checked the control board for a fuse.  Found two fuses on the printed circut board.  Checked both for continuity, one had none a 6.3 amp fuse sodered into the board.  went to a local electronics store and purchased a similar and replaced fuse.  Everything works fine now.
Jan 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machine Problem
It sounds like the control board has failed.  You will need a qualified LG technician to check this out.
Jan 20, 2008 | LG WM-1485FHD Front Load Washer
Open Questions:
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
