Question about Sony Cyber-shot DSC-H7 Digital Camera
Picture is vibrating
When i go to take a picture all of a sudden it starts to vibrate and so the pic comes out blurish
    Problem Solver:
  • 18 Answers
Is Steady Shot on or Off? It should be in the "Shooting mode" unless you are using a tripod.
If the vibration goes away when steady shot is off you probably have a failing gyro.
Posted on Jul 18, 2008
Juicer vibrates
THE SOLUTION TO VIBRATING. If it spins up ok and starts vibrating suddenly as you are feeling it, here's the solution: feed it very, very, slowly. that's it. i couldnt figure mine out, then realized that if i fed it slowly, it was just fine.
Aug 16, 2013 | Omega 1000 Juice Extractor
Steering wheel vibrating really bad all the sudden
you have an issue with a front tire more than likely. or could be the front rotor. I would bet my last breath its' tire or break/rotor related. Maybe even a wheel bearing but it usually doesn't cause vibration in steering wheel.
Jul 14, 2012 | 1995 Subaru Legacy
1995 CRE 650 power loss, vibrations
Possible retriction in exhaust. Maybe needs a valve adjustment.
Oct 23, 2009 | 1995 Suzuki DR 650 RS-E
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
Vibration from right front end
check wheel bearings , loose ball joints steering idler arm...
Aug 09, 2009 | 1998 GMC Jimmy
Check engine light trigger
that code is a torque convertor code. the vibration is coming from the trans. the trans pump could be going bad sending the vibration to torque convertor and ampflying the vibration.
Aug 03, 2009 | 2003 Mazda MPV
Vibrating and shaking
the sstepper motor of the focus assembly has slipped out of its track. that motor is a very powerful one which can cause the vibration.  once u change the mode to take the picture the motor should run in both direction to make some calibration. you cannot disable it. in the preview mode the optical assembly returns to it closed position and then the motor is switched off.
since it is a cybershot you need to be very careful in handling the camera if you have any plan to open it. it is recommended to be taken to the nearest service centre. any way the wheels might need replacement
Jul 04, 2009 | Sony Cyber-shot DSC-T300 Digital Camera
Enging vibrating at idle
1) It is very possible your engine mounts can be worn, but
2) the vibration you feel may be also due to the idle itself degrading to the point that the car is shaking. Does the engine sound like it is getting ready to die? what is the engine rpm when you feel the vibration? You may just have a dirty throttle body. In this case, clean the throttle body plate and bore and the problem will go away.
3) did the problem seem to come on suddenly or gradually, if gradually, you may just need some plugs and/or wires, and/or cap/ignition rotor, etc. (a tune up)
4) Also, do you only feel the vibration when the AC system is on?
5) there are some other reasons for abnormal engine vibration at idle, but the above are some of the most common, and simpler to repair.
All the best with the repair!
May 10, 2009 | 1991 Honda Accord
Vibration wont work
All I did was wait for it to come back. I think it might have had something to do with the battery being low. However, that's never happened to me when the battery was low. When I plugged my charger in, I got a text message. I had the ring on high and vibrate. It vibrated for a second, then it just continued to ring. Once my phone was fully charged, the vibration came back. I think it was just a glitch in the phone. Razr's suck.
Mar 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Sony Cyber-shot  DSC-H7 Digital Camera Logo
235 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
