Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
No display. Monitor won't display,it says it's in power saving mode, click any key or move the mouse. Have connected it to known working computers with same results.
  • 3,940 Answers
Http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Posted on Jul 01, 2008
I'm not getting a picture. When I push a button on the monitor it says, "In power save mode, press any key on keyboard or move mouse". Neither one of those things work.
If possible hook up to known good computer. If monitor works fine you have an issue with first computer/settings..Otherwise there is an issue with that monitor and it needs help.
Sep 11, 2015 | Dell E151FP 15" Flat Panel LCD Monitor
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
No desply monitor aoc crt problem
WHY IS THE POWER LIGHT ON MY MONITOR NOT COMING ON? Make sure the power button is ON and the Power Cord is properly connected to a grounded power outlet and to the monitor.
THE POWER LIGHT OF MY MONITOR IS ON AND THE COLOR IS AMBER, BUT THERE IS NO VIDEO OR DISPLAY. WHAT IS THE CAUSE OF THIS? Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Feb 04, 2011 | AOC Monitor
Green p0wer light flashing on screen but no display
Monitor is not on
Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep
If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
Connections not connected properly
vga.jpgMake sure that you are connecting the monitor to the back of the computer in the 15-pin connector as shown to the right or older computer 9-pin connection.
If the computer is properly plugged in, make sure it's getting getting power.
If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer and attempt to power on the monitor again. If the monitor still does not get power or it is not removable, it is recommended that the monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If the light is orange or flashing ensure that the monitor is not in a suspend mode by moving the mouse or pressing a key on the keyboard. If the computer does not get a display by moving the mouse or touching the keyboard, turn off the computer and monitor and reconnect the data cable from the back of the computer, and if removable, the back of the monitor. Turn the computer back on; if you still encounter the same issue, continue reading through the other possibilities.
Monitor settings are not correct
Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibilities.
No Post
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
Hardware Issue
If you have followed the above recommendations and are still encountering the same issue, it is likely that the computer may have either a bad video card or monitor. The best method of determining this is to do one or both of the following:
  • Disconnect your monitor and attempt to connect it to another computer. This can be a friend or family's computer and/or it can be taken to a service center.
  • Borrow a computer monitor and connect it to your computer. This will not harm the other computer monitor in any way.
If your monitor works on another computer it is safe to assume that the video card or potentially the motherboard within the computer is bad. Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your
Nov 27, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
No display
Envision monitor works on poewr but doesn't continue.
From the Envisiondisplay.com website's FAQ:
Q The power light of my monitor is on and the color is amber, but there is no video or display. What is the cause of this? A Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Jul 22, 2010 | AOC LM729 17" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Unable to get monitor out of power save mode
turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
>screen saver, click Power then change the turn of monitor tab
Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Flatscreen monitor
Solution: The following is monitor troubleshooting. If your monitor receives a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please refer to document CH000192.
Monitor is not on Make sure the monitor is on. If no power light (green or orange light) is seen on the monitor display try pressing the power button until it comes on. If no light comes on after several attempts continue to below connections not connected properly.
Computer is asleep If your computer monitor was on and you stepped away from the computer and upon returning it was black it's likely that the computer is asleep. Try moving your mouse, clicking the mouse buttons, and/or pressing any key (space bar) on the keyboard to wake it up.
Connections not connected properly Make sure that you are connecting the monitor to the back of the computer in the 15 pin (illustrated below) or older computer 9 pin connection.
video.gif If the computer is properly plugged in, make sure it's getting getting power.
Monitor settings are not correct Ensure that the brightness and contrast is turned up or attempt to adjust the brightness and contrast. If adjusting the brightness or contrast has no affect on the monitor continue reading through the other possibility.
Does the computer beep when it is powered on and/or does it appear that the computer has activity? If the computer does not beep or beeps abnormally it is possible that the computer itself is experiencing a hardware issue or is exhibiting .
Hope this works for ya/ Please dont for get to Vote.Thank You
Jul 18, 2008 | Dell Dimension 4600 PC Desktop
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
522 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
