Question about GE Refrigerators
ARE THE LINES AT THE BOTTOM OF AN UPRIGHT FREEZER SUPPOSE TO HAVE ICING AROUND THEM? ALSO RUNS CONTANTLY EVEN AFTER I INSTALLED A NEW THERMOSTAT. THIS IS A GE FREEZER
  • 481 Answers
Sounds like it has a small freon leak on the low pressure line. you may want to have it checked out by a professional.
Posted on Jun 30, 2008
Why is my freezer producing too much icing up.
Hi ,you usually have to give a fridge freezer a couple of hours to settle when it gets delivered if you had it switched on and then tipped it over you will have to start again . It looks like you may have to defrost it completely and start as if it was just delivered.
Oct 04, 2016 | Refrigerators
Bottom of Kenmore freezer vents icing up. Did test recommended weeks ago, replaced defrost timer. Worked fine for a few weeks and now is back to icing up and fridge not cool at all. Melted ice again with...
If the timer didn't fix your problem, and it sounds like it didn't, then there are 2 other components to a defrost system. The defrost heater, and the defrost thermostat. Both are located around evaporator. Back inside wall of freezer will have to be removed to access these parts. Thermostat will be clipped near top of evaporator coil. Heater will be near bottom of coil.
Sep 15, 2017 | Refrigerators
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Top coil in upright freezer icing up
its a manual defrost freezer, it is normal to ice up, if it is unusually more than you have noticed over the past 40 years, see if the door liner is cracked around the screws under the gasket, if so put some washers there to reseal the door liner
Nov 01, 2009 | Freezers
Upright freezer
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
Sep 19, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer froze on top thawing on bottom
Dispose of the unit and buy a new one. If it leaked the refrigerant out you have to fix the leak before charging it again. The chances of finding the leak are slim.
Sep 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
