Question about Magic Chef CER3740 Electric Kitchen Range
Oven beeping!! Hi I am having problems with my Magic chef oven! It keeps beeping and flashing F1. PLEASE HELP ME!!!
  • 117 Answers
Replace touch pad
Posted on Jul 19, 2008
Why does my magic chef oven, model 34HN-3TKXW, keep beeping and sowing -f1-
Your clock has failed and would need to be replaced, part number is 7601P155-60 but I was unable to find one for you. Maybe you will have better luck. Common rule is after 8 years they stop production of parts so I hope you get lucky in your hunt. Good Luck
Aug 06, 2014 | Magic Chef Ovens
I'm getting a constant beeping sound and a F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 10, 2011 | Magic Chef 9112 Gas Double Oven
My electric range keeps beeping and flashing F1. What do I do?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Magic Chef Kitchen Ranges
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
My oven is beeping and flashing F-1
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Magic Chef Ovens
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Annoying beep
On models where the keypad and electronic control are one integral part which can not be separated, an F1 error can be caused by a problem in the oven temperature sensor or its wiring circuit. If not it's the keypad.
Aug 07, 2008 | Magic Chef 31100 Gas Kitchen Range
-F1-
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board.  I would need the entire model # on sticker on the oven to see what parts are on this one.  If the touch pad is separate it will have a ribbon that goes from it to the board.  Unplug that ribbon, if the code goes away then the touchpad is the problem.  If the code stays with the ribbon unplugged then the control board is bad.  Make sure power is off to unit when touching anything!
Oct 12, 2007 | Cooktops
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Magic Chef CER3740 Electric Kitchen Range Logo
243 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
