Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinks wd 52525
I take that back it blnks 3x pause then 4x nothing on the screen
  • michele9886 Jun 30, 2008
    thank you so much I'll let you know if it works. Now one question I do have, I dont have sound coming thru will this also help?
    Thank you your awesome I ordered the part and Ill let you know!
  • Mitsubishi Master
  • 8,617 Answers
Thats a 34 code which means lamp abnormality. This is related to the bad capacitors on the PWB PCB just helped a guy last week repair his. You need the repair kit thats called V26 DLP PWB PCB Kit its 35.99 at the following link and contains all the capacitors and a CD that shows how to disassemble the chassis and identify the PCB and which capaitors go where. Heres the link and they also give free tech support to help you with the repair.
Posted on Jun 30, 2008
  • Sonny Berry
    Sonny Berry Jun 30, 2008
    yes the 34 code will stop sound cause the lamp wont light.
  • Sonny Berry
    They will work with you with instant messageing when you do the installing of the capacitors. They have a expert on mitsubishi DLPs he deals with all the mitsubishi customers He will help you get it straightend out.
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hello, I have a 52525 and the lamp indicator went
push the menu and device buttons on the front of the set both in together and hold for 6 seconds and see what two digit error codes blinks. It will most likely blink a 3 pause then 4 and then repeat the sequence indicating a 34 error for lamp abnormality which is almost always caused by faile capacitors on the Power pwb.
Jan 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Status light stays on solid red
Press the menu and device buttons on the front of the set both in together then count the led falshes. It will blink a series of blinks. Then pause for the first digit then another series of blinks and pause for the second digit then it repeats five times. Let me know what the two digit blink code was and I wil assist you with the diagnosis.
Dec 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 with blinking green light problem
The #3 post worked for me. I first just did the capacitors and it did not work at first, but I got it reset. It worked for 2 months and lost power the other day in a storm and the blinking light came again and would not reset. I put in the switch and followed his directions and it work perfectly. Sweeet. The switch was easy. The capacitors were not hard, but very detail oriented. I work on copiers for a living, so I am used to taking things apart and back together. You must be able to solder and reassemble pretty well, or I would hire someone to do it.
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
press and hold the menu and device/input buttons both in together for 5 seconds then the led will blink a number of blinks pause then blink another number of blinks then repeat that process. Let me know thw binks you get for the two digit blink error code.
Feb 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have what appears to be a 21 code
they dont have a 21 error they do have a 12 and a 22 error code. 12 means normal no error detecteced 22 is momentary upset after reset
Aug 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
