Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinks it blinks 2x pause then 1 nothng shows on screen
  • 927 Answers
Good Day, michele9886;
There is a long process to go through to isolate the problem, but here you go:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 uFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Good Luck, Big Irish.
Posted on Jul 10, 2008
Roland r8 has flashing green light
Are you using the correct AC adapter? An aftermarket unit will do this if the power is insufficient, or the polarity is wrong (- / +). If you're using an aftermarket unit, it may not be providing the right amount of Amps and Voltage to the unit; causing the display to blink. You can try this cord to help:
Jan 13, 2013 | Music
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi i have a presario cq60-114em, on power up i get the fan coming on straight away, the power and wireless led on, black screen,the hdd led flashes 2x then a pause then flashes 2x and carrys on with this...
1st Steve I would remove the hard drive and power up and see if you can enter the bios by tapping either F2 or Del keys. If you can get into the bios then great. Shut down and refit the HDD. Try and enter the bios again and see if the hdd is recognised. If not then the hdd is finished. If it does show then your windows installation is corrupt. Try starting it up with your windows cd in the drive and point the bios startup to see the drive a 1st boot device. If this works then try and perform a repair of windows from the disk.
Good luck
May 15, 2011 | Compaq Presario CQ60-220US PC Laptop
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Sep 11, 2009 | Televison & Video
The phone will not turn on. A red light blinks 3x
your battery full down plse seprate boost battery 6v before recharge phone
Jul 08, 2009 | RIM BlackBerry Pearl 8100
Have a Panasonic Projection TV PT-47wx51c. It is currently shutting it self off, then the red light in the front blinks and can not be turned back on until it is un-plugged. Just befor it shuts itself...
can you determine if the led blinks a certain amount of times then a slight pause before blinking again? Let me know as it may be blinking a diagnostic code.
Mar 28, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
165 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
