Question about Uniden Cordless Phone
Wont accept incoming calls
When the phone rings, I try to answer one of the extended phones in the bedroom, push the button but there is no sound. It will let me make out going calls, but nothing incoming. Can you help? Thanks, deb
  • 3 more comments
  • Anonymous Jul 16, 2008
    All Uniden phones do not answer
  • reneedouglas Jul 25, 2008
    When the phone rings, we pick up, they know we answered, but cannot hear us until we go to the base and press speaker. Both handsets have the problem just recently. Always worked before. I have a uniden powermax 5.8 ghz; model: TRU8885-2
    Please help!
    Thank you.
  • RyanandDarla Jul 31, 2008
    My Uniden set does the same thing, about once a month for a day or so... only mine all ring, but when you press the button.. it just says connecting and they all continue to ring.... as soon as the ringing stops, you can pick right up and call that person back.
  • Anonymous Aug 01, 2008
    1. incoming calls answer one pick up other phone phone dead
  • Hannah Schroeder
    Hannah Schroeder Nov 30, 2017
    It's weird that your telephone will let you make outcoming calls but not receive incoming ones. Mine works normally, but it won't ring when we receive calls. I don't know what you're going to do about your problem, but I'm going to find a telephone technician to see if they can fix it. http://www.onestepaheadcomms.com.au
This happened to mine , I never had aproblem before than one day ??? didnt work . I changed phone jacks ?? dont know why ??
1. Try disconnecting all phones in the household except the phone being affected.
2. Do a test call to see if the unit rings.
3. If the phone rings at this time, begin reconnecting all the other units one at a time. If the affected phone does not ring again, this is an indication that there are too many phones in the loop.
4. If possible try testing the phone on a totally different phone jack (friends or neighbors) to check if the same thing happens.
Also make sure the phone is not connected through an external answering machine, caller ID box, fax machine, computer, splitter, or defective DSL filter. If so then connect the telephone cord directly to the telephone jack and make a test call.
Posted on Jul 09, 2008
I have taken over a Binatone S 1545.I can phone in( getting ring tone on the phone) but cannot get connected when pushing the incoming call button
quite possibly you do not need to press on the incoming button it might be set for auto answer when you pick up the receiver
Nov 22, 2017 | Cell Phones
Phones do not ring with incoming calls
Check make sure ringer is turned up,push speaker button then push volume button a volume thing should show up on the screen,keep pushing volume button and it will. Increase the volume.ty.
Feb 15, 2014 | Panasonic KX-TG2632 Twin Cordless Phone
How can i accept the incoming call for myphoneTW1, it gets hard to accept such call, its ringing what button should i use to receive it.
When answering the call scroll down the screen and you will see the button "answer" and "cancel" on the upper screen.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 27, 2011 | Cell Phones
Already have unplugged everything twice and still will not accept incoming calls. The phone rings once and cuts off. Sometimes the single ring is heard only on the outgoing phone not on the incoming call...
Try reset the phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Jun 22, 2011 | Cell Phones
My phone only rings 3 times for incoming calls
There is no such option in motorola as i know to extend duration of incoming ring.
Apr 28, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Jun 02, 2009 | Lands Phones
Ringer does not work on incoming calls
If someone is calling, do you see it on the phone? If so, you may have muted the sound. Try looking for a a button with a music note on the phone. Hold that button for a bit(atleast that's how it works on my phone)
Feb 24, 2009 | Uniden 2.4 GHz Expandable Phone System...
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
No ringing tone or incoming call sounds.
The primary phone sets the ring for all phones. If it is off, nothing will ring. Once it is on you may set the volume of the rings on all sets individually. If you have the manual, look under Ringer Off on the main set. Hope this helps, let me know
Feb 18, 2008 | Siemens optiset E Corded Phone
Uniden Cordless Phone Logo
307 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
