Question about GE Dryers
Removing top cover to service gas dryer #DVLR223GEWW
  • 1,028 Answers
Remove screws jsut under edge at door opening lift front and pull top toward front
Posted on Jul 01, 2008
How do I get the top off
The front panel needs to be removed first before the top panel can be lifted. This is due to the top panel hold down brackets hidden behind the front panel posts. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order. Click on the link below for more detailed disassembly procedure.
Removing the Front and Top Panels of Maytag Sloped-Front Dryers
Mar 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
My dryer is making a high pitched squeal?
it could be the rear drum bearing,the front drum glides/rollers or the drum belt is glazed,or the tensioner for the belt needs replacement,all of which require you to remove the front cover by removing the lower front panel screws near the floor, then lift up front cover like a car hood and there are spring clips that will let go, then remove top cover these screws are underneath top cover in front and you can replace those items
Nov 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Getting back off
you dont, you start by removing the front cover, then you'll see the screws to remove to take top cover off,then remove drum belt and drum and your inside the unit
Oct 03, 2009 | LG DLE2532W Electric Dryer
One of the fins in my Maytag gas dryer, model Atlantis has come loose. I need to flip the tiop and need assistance
Unplug unit first and turn off gas .Page 5-2 of the service manual below (Similar to yours) will cover removal of front and top. Good Luck.
Service Manual
Sep 09, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
How to remove the front cover of my samsung front load gas dryer
take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
Jun 08, 2009 | Samsung DV448AGE Gas Dryer
Lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Apr 18, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Dryers Logo
83 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
