Question about Samsung DVD-V4600 DVD Player/VCR
Won't load DVD. Says LOADING but doesn't. - Samsung DVD-V4600 DVD Player/VCR
  • lee1928 Aug 15, 2008
    Won't eject dvd, shows loading but will not load.
  • hilly_b2000 Aug 23, 2008
    same problem. Put DVD, push close button. DVD player states that it is loading but it will not load the DVD
You have to clean the lens. if its not worked ,replace the lens
Posted on Jul 15, 2008
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
"Loading" screen
time for a replacement .
Jan 05, 2018 | KLH KD1220 DVD Player
Samsung blu ray player, dvd drawer will not open
Either the loading belt or loading gear wheels have the trouble. Sometimes the disc loading mechanism might need replacement. It won't cost mor for the mechanism. But will feel some difficulty in getting it from open electronic spare part market. it will be best to contact the authorised service center for Samsung to get it repaired.
May 12, 2012 | Samsung BDD5500 Bluray 3D Player
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
RCA L32WD26D TV/DVD/HD Combo - dvd wont eject
Hello
Check the loading motor and loading belt. If loading motor has damaged, or loding belt has broken or loose. the in-out tray mechanism won't work well.
Mar 03, 2012 | RCA L32WD26D HDTV/DVD Combo
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
DVD RECORDER JUST SAY HELLO AND NOTHING ELSE
Possible that the loading is not completing and so does not go into head loading. If the head loads and does not run then it is possible that the optical unit is faulty.
Also it is possible that if there is no response to after loading of disc the fault can be failure in the controller processor board or the loading drive. Try and clean the optical unit and see if there is any result.
Dec 01, 2011 | RCA DRC8052N DVD Recorder
Open-cloesh problems
Hello
Check its loading belt and loading motor. If loading belt get loose or loading motor has low pulling power [due to trouble with its carbon brushes inside it], this type of problem will occur. There is a gear wheel assembly inside it which draws in and pushes out the tray mechanism. If any of these wheels gets broken, the mechanism won't work properly, even if the loading motor and loading belt is right. If so, replace the loading mechanism. It won't cost more, and can be bought from most of the electronic spare part shops at your town. OK.
Aug 12, 2011 | Televison & Video
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Hello
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
Apr 24, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Samsung DVD-V4600 DVD Player/VCR Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
