Question about Panasonic SC-AK78 CD Shelf System
Surround sound speakers
Grease,
you mentioned a correct mode.. that would be what?
  • 58 Answers
Like you can change it to cd mode or tuner mode or a/v mode
Posted on Jul 05, 2008
No audio output in rear or surround
Assuming you have the sound configuration in the correct mode, then the chip circuit responsible for funneling sound to the rear and surround speakers is defective.
Jan 19, 2015 | Audio Players & Recorders
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
Two of my speakers are not working -no sound
If they are the rear surround speakers, they will not produce sound at all times, check this with a surround sound movie that will engage the speakers. Check the settings on the reciever to be sure you are in the correct surround sound mode, and check the movie menu to be sure you are playing in correct format. Also check that wires are correctly installed, observing polarity, under terminals at both the speakers and at the reciever. I hope this is useful, but not being onsite these are just a few troubleshooting tips to narrow the problem.
Feb 07, 2013 | Audio Players & Recorders
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
Whent I connet my android to my samsung HTC55 using the aux 2, just one speaker work, that is correct? is there a way to connect my android and all my speakers work
Your Android phone can only output in mono or stereo, but it does not have a surround sound decoder, so it cannot output natively to a 5.1 surround sound system. However, your HTC550 has a Surround Sound Mode called Dolby Pro Logic II, which will simulate 5.1 sound from any stereo input. Try activating Dolby Pro Logic II mode on your receiver to get surround sound on your Android phone.
Apr 28, 2011 | Samsung HTC550 Theater System
Nakamichi AV-7 (issue with surround mode - prologic)
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Aug 28, 2008 | Nakamichi AV-7 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
First you need to make sure that all the speaker wires are connected to the unit securly. next make sure that they are wired into the correct spots. then check and make sure that it is on the correct mode. please write back
Jun 30, 2008 | Panasonic SC-AK78 CD Shelf System
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
No sound in surround modes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Aug 15, 2007 | Onkyo TX-SV525 Receiver
Panasonic SC-AK78 CD Shelf System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
