Question about Toshiba Satellite Laptop Cooler
Toshiba Satellite Laptop Cooling Failure
Toshiba Satellite Laptop with error message "Cooling System failure, Cut off immediately Take to Service Center"Is this a recall or under warranty?
  • Anonymous Apr 27, 2009
    I upgraded memory in my Satellite A15-S129 to 1GB and the coling system failure message popped. I plan to use the cooling pad if that will resolve th eproblem or else, go back to original memory of 256MB.
    Genius:
  • 1,027 Answers
The fan has failed - warranty if in the time period since purchase.
Posted on Jul 04, 2008
There is a popup message frequently stating taht "Windows detected a hard disk problem. backup your files immediately to prevent information loss, and then contact the computer manufacturer to determine if...
Click on "Start". Click on "Computer" Right click on "C" drive. Click on "Properties at bottom of menu. Click on "Tools" Click on 1st of 3 options available, check both boxes to scan complete hard disc, this will run a 5 stage correction program upon reboot.
Dec 18, 2012 | Toshiba Satellite L505D-S5983,...
Hi, I have a new Toshiba Satelite L500 laptop. From the moment I started to work with it, following message began to appear: Warning: A problem with the cooling system has been detected. Please turn off...
first you should install an independent system temperature monitor like speed fan and check if your computer temperature is ok .If the temp is ok then it is not as much of a worry but more of an annoyance if it shows the computer is hot take it back to service immediately either way they should fix the problem under warranty.
I hope this helps Andrew A
Apr 01, 2011 | Toshiba Satellite Laptop Cooler
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
Software problem
SMART is the system that monitors the health of a hard disk, in your case  it's close to complete failure. Follow immediately what that warning message says - copy all your data to some DVD's, replace the hd and reinstall.
Oct 31, 2009 | Toshiba Satellite U300-ST3091 Notebook
Toshiba Media test failure, operating system not found error
That message means it is not reading a drive. Most likely the HDD. I would suggest you replace the HDD. That is likely the problem.
Feb 20, 2009 | Toshiba Satellite M305D Notebook
How to fix my Toshiba laptop in cooling system please ?
you probably need to clean the cooling fan...it collects dust over time, and doesn't move the warm air out as it should...its fairly accessible by removing the bottom case cover...please rate my response.....
Jan 29, 2009 | Toshiba Satellite 1715XCDS Cooling Fan...
Toshiba celeron satellite cooler replacement
first.you can find the processor fan in some computer shop,but i dont know if they will give you.second,check the model # of the fan and check in the internet for delivery or else,you can repair the fan by replacing the dynamo of the fan with another model of fan,just anly remove the screw of the fan and try to find another model fan and replace the dynamo fan.
This kind of issue is i try with some of my customer because they cant find the same model of fan.
Sep 18, 2008 | Toshiba Satellite Laptop Cooler
Laptop won't boot up
This is an operating system error, and sometimes indicates a hard drive failure. Start by running a system repair with your recovery or operating system disc. This usually takes care of it, if it doesn't, reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced.
Jul 31, 2008 | Toshiba Satellite A70 Notebook
Power saver error 0x5
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
Dec 10, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite Laptop Cooler Logo
3,304 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
