Question about Insignia NS-DV2G MP3 Player
Static on audio
I got no audio -just static -the screen and data are working,etc... but static in my speakers...tried several different headsets.etc...... ideas?
    Problem Solver:
  • 5 Answers
First I'd check to see if it's the same at both jacks, but it sounds to me like your DAC (digital to analog converter) may be bad. If so this won't help but... First be sure to back up any files onto your computer, then I would try to reset and reformat the entire thing and see if you can start from scratch. There is a reset button (for a unbent paper clip) on the side. You shouldn't lose any files doing the reset (Just did it on mine to be sure). Then if the problem still persists I'd try erasing the memory (from settings in menu) and/or rt click/format from your pc. This will erase all files and then you'll have to transfer one back to see if it made a difference. I don't know how, but I think I read of a way to reset the entire thing to factory settings, I'd do a search here on the forum to find out how and try that third if the other two don't do anything. I'm not an expert, just slightly educated on this so at your own risk and all that.
Also, I've read (only here on this forum) that best buy may fix or replace these players for free, I guess they've had a ton of issues with them and are just trying to keep people happy at this point. Good luck, please post to let us know if you find a resolution.
Posted on Jul 04, 2008
Audio static
That's pretty normal with built in connectors. For a workaround grab a cheap USB sound card from eBay or somewhere else. It worked for me.
High Quality External USB 2 0 3D Virtual 7 1 Channel Audio Sound Card...
Apr 08, 2017 | Lenovo IdeaPad Yoga 11S Touch - 59370514 -...
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Buzzing static sound in speaker
Static can be caused by a few things.
Does the static persist if you unplug the audio cable from your computer?
If so, the static is being caused by the amplifier built in to your speakers.
If not, the static is probably caused by interference on your sound card. Try plugging the speakers in to a portable media player. You might need to replace the sound card in your computer.
May 13, 2010 | Bose Companion 3 Series II Multimedia...
Static crackle on yamaha 6030 in 5.1 ..static dissapears if you switch to two channel. coming from bell hd pvr...and sony ps3. with ps3 i have to select audio from dvd or blu ray menu and then 5.1 and...
It might be a bad connection then. First try and swithch it to a different outlet and settings. If it does not work it mightn have to be fixed then.
Mar 28, 2010 | Yamaha HTR-6030 Receiver
My receiver is making a static through my speakers even when the volume is turned all the way down
Check the electric outlet to make sure the polarity isn't reversed, which can cause static. Also, check the outlets in the room to make sure they are all grounded which can also produce static. Also, certain cell phones operating a different frequencies can produce a static.
Feb 25, 2010 | Denon DRA-275R
Audio has a lot of static
You can possibly diagnose the problem by trying a different speaker,it does not have to be the same shape as the original but it has to have the same amount of resistance (ohms),radio shack might have one that you can try or one from a broken radio ,if you use one with different value it might not sound as loud but we are trying to see if you hear the static or is gone.You need to unplug the unit from the wall,remove the back cover and locate the speaker,disconect the wires and reconect the one to try then plug the set and turn it on,the antenna will need to be reconected too.Is the most simple test you can do without getting in too deep.Let Us know how it goes by a way of a new question or if you need more information.
Nov 01, 2006 | Sanyo HT32744 32" TV
Insignia NS-DV2G MP3 Player Logo
27 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
