Question about Sony SLV-N750 VHS/S-VHS playback VCR
How do you get codes for the vcr - Sony SLV-N750 VHS/S-VHS playback VCR
    Problem Solver:
  • 11 Answers
The book that came w/ the remote of call Sony
Posted on Sep 28, 2008
Gflight@yahoo.comdo you have the universal remote code for emerson dvd vcr combo ewd2202
Hello
Unversal remote setup codes for Emerson DVD/VCR combo are:
0456 [0458 0227]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK
Aug 13, 2011 | Emerson EWD2202 DVD Player/VCR
I need the code to program the remote to an emmerson ewf2006 tv codes
Hello
You haven't specified whether it is a TV/DVD combo or TV/VCR combo.
Four digit universal remote codes for Emerson TV/VCR combo are:
0227 0233 0254 0264
0265 0266 0310 0325 [0039 0252]
[0147 0250] [0147 0257]
For TV/DVD combo is: 0456
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR
Jun 19, 2011 | Emerson Televison & Video
I need a code for our Samsung TV/VCR using a universal remote RCA RCRN04GR. Would greatly appreciate your help!
Hello
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR.
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
0358_0942
Nov 22, 2010 | Samsung CXJ1352 13 in. TV/VCR Combo
What is the vcr plus code? where do I find it?
i would like to obtain codes to record programs on a vcr that needs vcr plus codes
Mar 06, 2010 | JVC DR-MV1SU DVD Recorder/VCR
Need vcr codes for samtron vcr to program universal remote
I did use the Samsung code for my Samtron VCR...in fact one code worked for my TV foo....worked perfectly
Oct 09, 2009 | Televison & Video
Remote control codes
RCA Universal Remote Control Programming Codes
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Find codes for device and brand below.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  3. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
RCA Codes for VCR
000,005,007,008,028
035,037,054,069
Nov 04, 2008 | RCA VR557 VHS VCR
Orion vcr code
  1. what code do i use fpr orion vcr
Sep 26, 2008 | Orion VR213 VHS VCR
Need codes for rca universal remcon to emerson vcr and need codes for emerson vcr and coby 224 dvd
Try these codes for the emerson:
Code 003 for Emerson VCR Code 007 for Emerson VCR Code 012 for Emerson VCR Code 014 for Emerson VCR Code 015 for Emerson VCR Code 021 for Emerson VCR Code 024 for Emerson VCR Code 025 for Emerson VCR Code 026 for Emerson VCR Code 029 for Emerson VCR Code 031 for Emerson VCR Code 032 for Emerson VCR Code 033 for Emerson VCR Code 038 for Emerson VCR Code 041 for Emerson VCR Code 054 for Emerson VCR Code 065 for Emerson VCR Code 116 for Emerson VCR Code 130 for Emerson VCR
and I wasn't able to find any for the dvd player :/
Jun 13, 2008 | RCA Universal Remote Control
Daewoo tv/vcr combo ccodes
Hi here are some codes I have 0278 0624 If they dont work try programing the VCR
first then the TV. To program the VCR put a tape in and put it on play after you put
the code in hit the power button the vcr should stop playing. If that works then program the TV.
Some TV/VCR combo's require two codes. Good Luck
Mar 02, 2008 | Daewoo DVQ9H1FC 9 in. TV/VCR Combo
Code for remote control; vcr cmv61001
Most universal remotes provide some method of scanning through all the VCR codes 1 at a time, when you see the vcr go off you would then store that code. Read the book...
Geno
Feb 09, 2008 | Curtis CMV61001 VCR
Sony SLV-N750 VHS/S-VHS playback VCR Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
