Question about Uniden Lands Phones
How to set up the security code to check my messages when not at home.
  • 1 more comment
  • mswarrow Jun 30, 2008
    Just says 5.8ghz also behind the battery in the handset the model number is CXAI5198
  • Patrick McGee
    Patrick McGee May 11, 2010
    All I know is it's a uniden
  • Patrick McGee
    make and model please.........
  • 405 Answers
Allright,
Well for starters if you need a manual for that you can get it here:
http://www.uniden.com/pdf/CXAI5198om.pdf
The first thing you need to do is set up a security pin for the remote access, see pg 42 of the manual
Then see pg 49 for remote instructions.
Basically set up the pin, call your house and during the answering machine greeting press 0 and the pin you just set up. Follow the voice prompts to listen or delete messages.
Good Luck
Hope tis helps
Posted on Jun 30, 2008
How do I retreive messages from the answering machine remotely?
this is pertinent to uniden dect 1653 series and may work on yours as most uniden systems use the same format
1--call your phone number and wait until the system answers( if it is turned off , it answers after 15 rings and sounds a series of beeps
2--- during the greeting or beeps , press the # and immediately enter your security code . If you enter it incorrectly 3 times , the system hangs up and returns to standby
3--- the system announces the time and the number of messages in the memory and a help prompt. It beeps to let you know it's waiting for a command
4--when you hear the beeping , enter , enter a 2 digit code command from from the chart for example to play a message press# then 2
if you don't press any keys for 15 seconds the system hangs up and returns to standby
the chart codes are
#1---repeat message
#2-- play message
#3--skip message
#4 --delete message
#5--stop play back
#6 turn system on
#9---turn system off
#0 hear help prompts
to get your security code -- programming a security code
the default security code is 80
1-- with the phone in standby, open the menu from any handset
2-- select ans setup, the select security code
3-- use the number keypad to enter a 2 digit security code ( any numbers in the 00-99 bracket) Press menu/ select when you are finished
remember to note your security code
if this doesn't work on your set up go google and type in user manual for (make and model ) cordless phones-- and print out any pdf version down loads
Jan 09, 2016 | Uniden Lands Phones
How can I retriev messages from my home ohine/ansering machine???? PLEASE help. Model # 29893GE1B
Greetings:
To retrieve your messages from another phone call your telephone number and when you hear the beep enter your 3-digit security code (if you haven't set it the default code is 1 2 3). The answering machine will beep to confirm the code. You can skip the greeting by entering the security code anytime during the greeting.
To hear your messages locally press and release the PLAY/STOP button. To stop playback, press and release PLAY/STOP again. To restart the message that is playing, press and hold PREVIOUS until the message restarts. To replay the previous message, press and release PREVIOUS. To play the next message, press and release NEXT.
Hope it's all good news - Thank you for using FixYa.com.
Mikeywaf
Mar 11, 2011 | GE 29893GE1 Corded Phone
I have a ge 25861ge3 answering system and would like to be able to check messages remotely but don't know how to set a code HELP
The default security code for accessing the answerer from another location
is 1 2 3. You must use the handset to change the security code. With the phone OFF (not in TALK mode), follow these steps:
1. Press trans/answerer button.
2. Press *exit.
3. Enter the three numbers to be used as the new security code.
4. Press *exit again.
5. You will hear the new security code being repeated to confirm the change.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/25861_CAN_EN_CL_IB.pdf
Feb 11, 2011 | GE 25861GE3 Phone
I have a Motorola Phone Model MA361 How do I get my messages from another phone when I'm not home?
according to the phone's manual:
Checking Messages from Another Phone
? Dial the phone number of this phone.
? When you hear the announcement, press the security
code (the default security code is 123).
Dec 28, 2010 | Motorola Mobility MA 361 Cordless Phone
How do your retrieve messages from home while away from home
Here's the manual:
29869GE2 Digital Answering Machine
You will need to set a security code. When you're away you can call your home phone and enter the code to retrieve your messages. Hope this helps.
Dec 29, 2008 | GE 29869GE2 Digital Answering Machine
Retrieve Messages when away from home
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home
Sony TAM-100 Answering Machine
Step I: Set the Remote ID (security code) on themachine itself:
1 Press (SET/REC).
2 Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code. To select, pressthe SKIP or REPEAT button. To enter,press the SET button”.
3 Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW). Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4 Press (SET/REC). The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code). The new code will replace the old one.
Note: If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
Oct 24, 2008 | Sony TAM-100 Digital Answering Machine
Security code N 73
u need to concern the nokia care
Aug 13, 2008 | Nokia N73 Cellular Phone
CHECKING MESSAGES
First call your home number, when the answering machine picks up, dial 0 then the two digit security code. (You have to check the security code on the handset.) It will then give you voice prompts how to listen, skip and delete messages.
Jan 22, 2008 | Uniden TRU9280-2 Twin Cordless Phone
Messages from out of town
First you have to set a security code. Program the secutity code at the machine by holding the Stop/Set key and the Next key down at the same time and follow the voice prompts. Once you set the security code, (it will be a 3 digit code) when you call home while away while your greeting is playing key in the 3 digit code (no star, no pound key, just the 3 numbers in the code) and it will take you to the message menu. Test it while you are at home with a mobile phone. Hope this helps.
May 30, 2007 | GE 29888GE1 Digital Answering Machine
Lands Phones Logo
277 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
