Question about Matsushita Computers & Internet
Matsushita monitor, JZNC-OP147-1
I need a service manual for the above monitor, the uper half of the screen is stretched vertically, and "shakes", gets worse as system warms up more.
    New Friend:
  • 39 Answers
PLZ Visit www.eserviceinfo.com
Posted on Jul 02, 2008
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
My 933sn has this stupid problem. when playing old games at 800x600 half the screen gets streched vertically. i play all the other games at 1360x768 but some like age of empires 2 or counter strike,...
Try changing the resolution your TV is putting out; it may not be in full screen, but at least everything won't be stretched! 800x600 has a different ratio than 1360x768
May 06, 2011 | Samsung 933SN Monitor
My monitor 17" Samsung 794MG CRT. Already Display setting 1024 x768 (Problem is Screen are Vertically Shake) Request you to give ideal settings for display of above monitor
This depends on your video card's capabilities. Try setting it to the lowest value, and then work your way up. If the screen is shaky, this may be a monitor problem. You may also try to set the refresh rate for the monitor lower, as this can be the cause of shakiness.
Sep 30, 2010 | Samsung 793DF 17" CRT Monitor
Right half of screen blanks out
Hi...there,
Well... after 3yrs of used, it's time to retired. You've got a busted panel...
Dec 01, 2008 | Philips 230W5VS (Silver) 23" LCD Monitor
Vertical distortion
try to replace all capacitor in vertical section a leak capacitor can make your screen to shrink....
Sep 12, 2008 | NEC AccuSync 90 19 in.CRT Conventional...
Distortion in Monitor
Your problem is simply a leaky capacitor on the vertical oscillator circuit on your monitor. Try replacing the ones with 10uF values.
Aug 10, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Problem
1. problem in vertical section .
2. Vertical IC supply capacitor problem.
3. Drypoints in Vertical IC saroundings.
4. vertical IC problem.
Jul 20, 2008 | LG Studioworks 552V 15" CRT Monitor
1080i picture is vertically stretched
You can get the service manual emailed to you instantly if purchased from the following site and they offer free support to help you diagnose and repair your set.
http://servicemanuals.vstore.ca/
Nov 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
SHAKING IMAGE, STRETCHED IMAGE
Like I said last night cobra there is a vert shaper cap off the jungle/drive ic usually a smaller value and will check good but its bad. Or the b+ filter cap off the fly has caused sysmtoms like this as well. Good Luck
Apr 14, 2006 | Dell 828FI 15" CRT Monitor
Computers & Internet Logo
71 people viewed this question
Top Matsushita Computers & Internet Experts
John Anderson
John Anderson
Shaukat Bhutto
Level 1 Expert
Are you a Matsushita Computer and Internet Expert? Answer questions, earn points and help others
