Question about Kirby G5 Bagged Upright Vacuum
Vacuuming it is hard to move forward when vacuuming,ok when moving back
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=725106
Vacuuming
Posted by egarcia on Jun 30, 2008
It is hard to move forward when vacuuming, ok when moving back
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds like you have a Kirby vacuum and there are a few things you may want to try. #1. Change the belt on the vacuum every 4 to 6 months for the best cleaning and the belt also helps you with the movement, and to store the extra belts in a Ziploc bag in the refrigerator. #2. There is an adjustment on the brushroll on each end of the brushroll by turning the screw heads and ½ to 1/3rd turn on each side. #3. if the belt is changed and the brushroll has been adjusted then on the height adjustment, try this… raise the height adjustment to the highest level and then adjust is down one step @ a time until you hear the tone change, that is when the brush hits the carpet and the vacuum head creates a seal. Then try to vacuum the carpet – if you feel like it is doing a good job then you have got it adjusted correctly, if not adjustment one more down and the setting should be complete. If the setting is all the way down on the floor the vacuum cannot do its job properly. Also it a good idea to change the vacuum cleaner bag; and to clean the inside of the cloth bag. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
Why does the dyson DC65 not move forward
If something is restricting the ball from spinning freely it will make it hard to move.
Oct 18, 2017 | Dyson Vacuums
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
Why is my DC33 too hard to push on carpet?
Sounds to me either the belt is broken or the brushes on the brushroll are worn off enough as to not grab the carper as you move it forward.
Feb 14, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Self propel not working
Make sure the replacement belt was the right one/size.
Make sure the self propelled is on at the handle. If you replaced the flat belt and it still pushes hard the most common problem is a broken power drive cable or actuator arm. Put the handle down and move the power drive handle forward and backward. If it moves freely watch by the headlight for the cable to move the actuator at the base. If the cable is in tact it should move the actuator. If it is broken the actuator will not move. If the actuator is broken the piece of plastic holding the cable will let the cable slide or it may be broken off completely. Replace whichever is broken.
If the cable system is ok and the belt is correct you may have a bad powerdrive assembly. I will include links to correct replacement parts.
Actuator
http://www.vacuummedic.com/product.php?id=363
Cable
http://www.vacuummedic.com/product.php?id=362
Belt
http://www.vacuummedic.com/product.php?id=6
Good Luck!
Aug 23, 2012 | Hoover U6446-900 WindTunnel Bagged Upright...
Pushes hard over the carpet and left lines in the new carpet. My father pulled it backwards and seemed OK. It just pushes extremely hard forward. The Dyson is about four years old and have not had any...
Check the axles of the wheels for debris accumulation. Also, make sure the height is set for the type of carpet that you have. Try pushing the machine on a bare floor--is it hard to move there also? Hope this helps!
Nov 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My Kenmore Progressive keeps burning up belts even after I have changed the bag, cleaned the filters and checked to make sure the agitator was clean and free turning
The solution is to change the agitator. They wobble and displace the belt. Change it and you will have a new agitator with new bearings. It will keep it in line. It has to be in line with the system. Any shaking of the belt & lets go to the Kenmore store. I had the same problem.
Jan 17, 2010 | Kenmore Vacuums
My Roomba will not move forward. It will try and spin itself and then try to move forward but then spin itself again until it stops and beeps. I tried cleaning the whole unit but it still is unable move...
Hey
is it 5xx Roomba ? is it 9 beep that it sounds ?
Please look for other same problem posted here ;-)
You are probably facing a bumper sensor issue.
Try to clean the bumper first and if this goes on, either call iRobot service, or
take a look at this page for the step by step 9 beep fix.
Have fun
Avi
Aug 03, 2009 | iRobot Roomba 530 Robotic Vacuum
I robot won't go forward
Apache Server at www.youtube.com Port 80
May 29, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Back wheels not turning.
See if the pedal is set on D
Check if there is some resistance to move pedal from N to D and back - maybe pedal is broken...
See if handle slides back and forth a bit (maybe slide is rusted)
if everything is fine - Inspect primary drive belt. That will require to get inside the vacuum... See instructions HERE
If everything above is ok - you may need to replace a tech drive.
Good Luck
Nov 13, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
74 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
