Question about Hitachi Televison & Video
Hitachi 50ex10b looking for an ihvt for this projection tv  part number fbt c90luiprc  can anyone help
We just got a used hitachi 50ex10b tv... it did not come with the remote, and i needed help adjust the setting.. like the color and speakers... how do i do that
Posted on Sep 20, 2010
Adjust Hitachi 50ex10b
Its a very old set, what are you trying to do?
May 25, 2012 | Hitachi Televison & Video
Hitachi Projection TV
it seems that yo got the problem on the video output module.. try to look and check for any defective resistor on this area..
BTW.. when the picture come out did the color was normally detailed..?
Oct 12, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 57f500a e907 fuse blew on the power supply board, replaced e907, and it went again. Is this a problem on the power supply board or the deflection board? Where should I start looking next?
If QH01 is shorted again, then this is an indication that the FBT is already faulty causing QH01 to shorts right away and blew E907(self destruct when shorts occured on the line). 100VDC isn't causing E907 to blew, you've only got 100VDC because the FBT didn't oscillate yet. Before you replaced the FBT make sure to test all parts parallel on the B+ line like DH09, Q701, CH16, CH13, CH20. It is better to pull-out the FBT while testing the shorted/leaky parts on the board to make your reading more accurate. If you found the said parts to be in good condition, then you have to replaced the FBT.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 03, 2011 | Hitachi 57F500 57" Rear Projection...
My 50 inch hitachi hd projection tv picture won't
This T.V. more than likely has a bad lamp. I don't know the model number so look up on ebay for a lamp replacement by model number after you inspect it and find it to look cloudy or exploded.
Jun 20, 2011 | Hitachi Televison & Video
I HAVE A SONY KP-FW46M31 PROJECTION TV, LED BLINKS 10 TIMES WHEN SWITCHED ON THEN TV SHUTS DOWN. THERE IS SOUND BUT NO PICTURE?? CAN ANYONE PLEASE HELP WITH A SOLUTION. I HAVE HAD ALL BOARDS OUT AND DUSTED...
It could be your high voltage trippler that connects to FBT flyback Transfomer. Let me know if you need any more help. Mats has parts 1-800-628-1118
Try Partsore.com and Google to Encompass Parts Distribution and type in your model number,see if they have Free swervice Manual you can print out online.Also Type in your search bar Understanding Sony Blinking Codes
Jun 02, 2010 | Televison & Video
Hi I have a hitachi LCD projection TV my lanp and
yes you need a lamp about as sure as anyone can be without looking take lamp out see if its brke inside or has any whit smoke spots in it
Feb 06, 2010 | Hitachi 50VF820 Projection TV
I have what seems to be the common light engine problem with our 55VS69A Hitachi TV. I need to contact Hitachi. Do you have the #?
Hitachi's Service Hotline number is 1-800-448-2244 (1800-HITACHI). They do not sell parts direct but can give you all the information for local servicing and authorized parts dealers.
Now if anyone knows the exact part number for the "light engine" in the 55VS69A, we might get once step closer to a solution for this common problem. Anyone?
Jan 30, 2009 | Hitachi 60V500 60" Rear Projection...
Hitachi 46UX50B high voltage transformer issue
Hello Bour,Its not too Bad,You gonna need a Couple of Things,Solder Wick,And a Soldering Gun,As you Pull ooff the Back of the Set.Youll find Probley 8 Screws Holding the Deflection Module(that will be the One with The High Voltage Tranformer on it(IHVT)You will have to look good on the board for all screws.....The Red lead tha come out of the IHVT Push down and Turn it should Come loose,The follow the g2 Lead to a Screen focus Bluck and pull on it it will come loose from it Note wher this lead came from,Once you have the Board loose,Turn it over and Put the Solder wick on the Connections and apply Heat,Solder will be sucked up by the Wick and you do this with each Conn,Till the IHVT is Loose(Note)Solderwick is available at Radioshack,Hope this Helps Perry
Jun 20, 2007 | Hitachi 46UX50B 46" Rear Projection...
Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Jun 04, 2007 | Hitachi 46F510 46" Projection HDTV
Televison & Video Logo
107 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
