Question about Brother MFC 7420 All-In-One Laser Printer
Toner life ends
I refilled the toner cartridge drum but the memory says " toner life ends". What to do?
  • cbthunder Sep 18, 2008
    I have the same problem with a brand new toner cartridge.
  • Anonymous Mar 27, 2014
    How do I remove memory effects from refilled cartridges
  • 134 Answers
There are two units in the machine, a toner cartridge and a drum unit. The toner clips into the drum and then is inserted in the machine. If you changed the toner and you still get this message, you may have a bad or damaged toner detection sensor.
Posted on Jun 30, 2008
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
Red alarm light flashes..Reads ...prepare a new drum
your drum unit is near end of life.
you will have to buy something like this
http://www.dura-toner.com/canon-ep87-drum-unit-cartridge-imageclass-mf8170c-mf8180c-drum-ep87dr.html?AdID=352--EP87DR-R
i am showing you just for example, search local stores for cheaper.
you can also give it for recycle, just find some toner refilling company near you.
Sep 19, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
It tells me tone life end, I replaced drum unit and toner and it still says life end
try this. open the front cover, press the "options" button, then "start", then "1" then "0". once you see the message "close front cover", close it. if message comes back, you may have a faulty or "refilled" cartridge. if toner cart is not "reset" properly when refilled, you will get this message also.
good luck,
razors
Jan 14, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
May 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
Fax machine 2820
Make sure that you are not using generic supplies. Using generic supplies or supplies that have been refilled will cause the unit to give false errors. There is white piece of plastic inside the semi circular opening, if you do not see a white semi circular opening it is either a generic toner or starter toner and you will need to replace the toner with a authentic toner. You may try this also: 1. Remove the drum and toner, separate the drum and toner and then rock the toner from side to side. 2 Put the drum and toner back together and clean the corona wire ten times. 3 Put the drum and toner back inside the machine and close the cover, if you still have toner life end try this: a Open the front cover b press the options key, the LCD will say "replace drum?" c press the start key. and then press 10 on your dial pad. the display should say accepted for about 2 seconds and then say cover open. d close the cover, if the display still has toner life end, you will need to replace the toner
Oct 03, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 7420 All-In-One Laser Printer Logo
790 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
