Question about Ovens
My oven will not shut off. I had to shut off the breaker to the range. What do I need to replace to fix this?
  • Ovens Master
  • 43,501 Answers
Here is a tip that will help you figure out why your oven will not shut off...
Electric Oven Problem Oven will not shut off
heatman101
Posted on Dec 14, 2010
SOURCE:
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
My kenmore elite stove model#790 the oven and broiler do not heat up but the fan runs
Since none of the burners or elements will heat, I recommend that you shut off the house circuit breakers for the range. Your symptoms point to a voltage supply problem. The range should have a double breaker (the two circuit breakers are probably connected together with a metal clip). The range clock control will light up if only one leg (L1) of that power supply is provided to the range. If the second leg of power (L2) is missing, then none of the burners or oven elements will heat. You could have a problem with the circuit breakers or the wiring on the terminal block at the back of the range. With the breakers shut off , I recommend that you pull the range out and check the wiring on that terminal block. Based on your description, you may find a loose connection or burnt wiring in that area. The image below shows wiring information for the terminal block and the junction box for the range. This information should help you check that issue. If you can find a wiring failure and restore a proper voltage supply to the range, then the stove top burners and oven elements should heat properly.If you find no problems with the wiring, then you could have a bad circuit breaker or a problem with the house voltage supply for the range. An electrician will normally need to diagnose and repair that type of failure. I hope that this information helps. If you need more assistance, reply with additional details. If you need parts, you can order them from the Sears PartsDirect website.If you get to a point where you need to have a service technician repair this failure, you can schedule service through this link: Sears Home Services .
Nov 27, 2012 | Ovens
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
The oven made a popping noise, and the breaker shut off. When I reset the breaker. The range eyes were still working, but the oven was gone. Model is FEFL77ABH. IS this an element issue. If so how do I get...
You will need to remove the back panel and check the wiring to the elements.If the wiring seems to be good then you will need to check the continuity of the heating element if you do not have any then it will need to be replaced.
If the wiring and the element are good the you may need to replace the main electronic control board
Dec 25, 2010 | Frigidaire Ovens
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Will not come on after self cleaning
this is a common occurance with many self clean ranges, especially slide in and wall oven units. the kitchen aid ranges usually have a non reset hi-limit. meaning it opens one time and needs to be replaced, sadly.
to replace the thermostat can be tricky to do if you're not experienced, so if you have any reservations about taking you range apart, call a qualified tech in your area. if you decide to take a go at it, well first things first.
**FIRST unplug from the wall or shut off the breaker**
*the other issue is not knowing what model you have.
I can tell you most recent kitchen aid units made by whirlpool have a fixed hi-limit at the back outer oven wall. remove the rear panel, and the hi-limit should be easily accessed. that part # 8300802
hope that helps,
good luck
Sep 28, 2009 | KitchenAid Ovens
Oven shut down
hi If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.
If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
thank u........
Sep 12, 2008 | Ovens
Fisher&Pakel Oven os301
re-boot, I shut the breaker down for a few seconds and bingo, problem fixed
Aug 07, 2007 | Fisher and Paykel OS302SS, Stainless Steel...
Ovens Logo
155 people viewed this question
Top Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
