Question about Toshiba DKT-2010 Corded Phone
Only works on speakerphone
I have numerous DKT2010-SD and DKT2020-SD that only work on speakerphone. Any idea why this is and how to remedy?
  • Anonymous May 08, 2009
    I have a similar problem with my DKT2020-SD.
    My issue is defiantly my phone not the jack because I tested a working phone on the same wall jack as the broken phone and it worked fine.
    When I pickup the handset the phone doesn’t go to a line it just acts as if I didn’t pick it up. I tried using a handset that I know works but that didn’t fix the problem.
    If I hit the speaker button the speakerphone works find but it doesn’t respond to the handset.
    Is this something I can fix if I open the phone up?
    Thanks
  • Sherb99 May 08, 2009
    Thanks
    Scholar:
  • 108 Answers
It sounds like maybe one of the PDKU2 station cards might be bad if you have numerous problems, can you take one of the correctly working phones and plug it in to the phone jack for one of the phones that is not working and see if it works correctly or not. That will help narrow down the problem. Let me know ...Mike
Posted on Aug 08, 2008
How to set the time on a Toshiba dkt2010-sd phone system?
I tried looking through the manuals and finally came upon a reference that said the System Administrator Guide was where to look because only that special system was able to do it.
It has the instructions to set the time on page 12
http://www.deltaintellicom.com/wp-content/uploads/2014/07/System-Admin-Guide-Toshiba-DK-Systems.pdf
Nov 08, 2016 | Toshiba Office Equipment & Supplies
Toshiba DKT2020-SD
Do not press the conf/transfer key.
press the intercom button first.
Then press the day key or dial ext number.
Tony
732.720.9369
May 20, 2014 | Toshiba DKT-2020 Corded Phone
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Please download me instructions on how to change time in our Toshiba Phones at work with Model No. DKT2010-SD. Also I am requesting a Manual for the Toshiba DKT2010-SD phone system. Your tech support...
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial As far as the system manual goes, I'll need to know the type of system you have. Toshiba DKT2010's work with a number fo different Toshiba systems. To find out, go to where the phone system is located and look at the top corner. It should have a number designation there such as DK 40i or DK280 etc.
Nov 08, 2010 | Toshiba DKT2010SD Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
Oct 30, 2007 | Toshiba DKT-2010 Corded Phone
Trying to change the time on my Toshiba dkt2020-sd phone. I don't know how to do it.
Business phone systems have one time setting for all telephones. It is s syatem programming feature and not something found in a user guide. Follow this link for information on changing the time on different PBX phone systems. http://www.tel-programmer.com/time_setting.html
Feb 21, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
270 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
