Question about Lomo Supersampler 35mm Point and Shoot Camera
Super sampler How to get film out?
Hi I can't get film out of my lomo super sampler!!
Once you rewind the film line up the arrows on top of the winder then gently lift the winder to release the film canister
Posted on Aug 06, 2008
How to rewind roll film in Lomo Action Sampler 35mm Point and Shoot Camera?it stucked
To rewind the film on your camera you push down on the rewind handle on the top left of the camera (as viewed from behind) and turn the rewind handle clockwise until no more resistance is felt.
Once the film has been rewound, slide down the catch on the left edge of the camera body and open the door on the back of the camera.
Courtesy of alfredklomp.com you can download part one of the manual here and part two here.
If after all this, the camera is broken then it cannot usually be repaired: it's designed and built as cheaply as possible as a toy camera and is only designed to last for a few rolls of film. Spare parts are not available, but some broken parts can be adapted or fabricated from whatever is to hand to do the job.
Based upon the question you asked, my reply should have solved your problem so please take a moment to rate my answer. If the problem has not been solved then add a comment instead and I'll be happy to provide further assistance.
Mar 23, 2010 | Lomo Action Sampler 35mm Point and Shoot...
My action sampler doesnt work properly.. i have loaded the film and shoot correctly, i guess :d but the result is not in four panels, but just like an usual film cameras (in 1 panel only).. what's wrong?...
The problem is your lab, assuming you got prints, the lab printed them like normal, But look at your negatives, you will see the 4 panel images.
Best to print an Actionsampler photo from the internet or lomography website, just print a rough one on regular paper, 4x6inch, and take it to the lab to show them how the prints should be. They should re-print from your negatives for free because they made an error the first time. It may have been an automatic adjustment by the machine they use.
Dec 19, 2009 | Lomo Action Sampler 35mm Point and Shoot...
The shutter button does not appear to click down and the lense does not open so no picture is taken. Usually it makes a sound and you know the picture has taken. HELP MEEE????
I had a similar problem with another brand of this type of camera. I would click the shutter and hear it open but it would not go through the series of four lens exposures unless I manually turned the film advance wheel . I think it may be because the motor isn't strong enough to draw the film across and trigger the shots. cheap plastic, ya know. I never got the film developed but im interested to see if it got anything at all.
Oct 28, 2009 | Lomo Action Sampler 35mm Point and Shoot...
My super sampler wont click after i take my firs shot??
Pull the string to advance the film. As long as your film sprocket holes are lined up with the sprockets in the camera, your shutters will fire the next time you press the shutter button.
Dec 31, 2008 | Lomo Supersampler 35mm Point and Shoot...
I can't seem to click to take a photograph
Pulling the string doesn't take the picture, it advances the film. Press the button on top of the camera, you'll hear the shutters go, and then pull the string. Just make sure the film is taut when you load it, and that you're not yanking on the advance string too hard.
Rewinding film at end of roll
Try looking here:
http://www.lomography.com/about/faq/1637-how-do-i-rewind-and-remove-film-from-my-lomography-oktomat-camera
Sep 03, 2008 | Lomo Oktomat 35mm Film Camera
Lomo super sampler problems
Hi Vicky,
Yes I will be glad to have a look at your Lomo if you care to email me I will send you my contact details
SUPER8
Aug 19, 2008 | Photography
My lomo will not advance the film after taking a shot
I fixed this a couple of ways with my own LCA.
One is to stick a piece of paper in between the 2 parts of the tape-up spool (the internal and external parts) to make them a tighter fit.
Also, I often fold the leader of the film back (very close to it's end), and push it inbetween the 2 parts of the take up spool, making sure one sprocket is securely placed into the small tooth/hook on the spool. So, the film is folded around the tooth and towards the back, on the inside of the spool.
Jan 08, 2008 | Lomo Kompakt Automat 35mm Point and Shoot...
No pictures at all, at it's best just blury colours
got my developed film back and all I got were pictures seperated into 4 boxes with one colour a box. can you explain more can you look at the negatives and see whats on them. try a sunny sixteen rul on a sunny day with sun high in sky set camera aperture to F16 if you are using ISO100 film set the camera shutter to 1/100th ISO 200 = 1/200th etc take a picture of a stationary subject - like a brick wall whats the make and model of the camaera
Apr 13, 2007 | Lomo Action Sampler Kit Camera 35mm Point...
Lomo Supersampler 35mm Point and Shoot Camera Logo
313 people viewed this question
Top Lomo Cameras Experts
Are you a Lomo Camera Expert? Answer questions, earn points and help others
