Question about Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range
Setting of clock
My nephew has been playing with clock & cooking controls so no gas will come out . We are unable to rest clock to enable us to cook
  • Anonymous Oct 26, 2008
    can,t reset the clock
You need to examine the timer settings. Perhaps you could turn off the power to the oven for a few minutes - this might reset the timer.
Posted on Sep 09, 2008
New whirlpool range settings no responding, cook top works good Rest of control not working
Uriel,
Have you tried setting the clock yet? I worked on one last year that you had to set the clock before the oven controls would work.
May 26, 2015 | Whirlpool Kitchen Ranges
Maytag walloven m# cwg3600aab Try to start. F5
Hi and welcome to FixYa, I am Kelly
I checked both types of Maytag oven fault codes and they both come up with the same fault.
Sadly this is telling you the Clock assy / ERC has failed.
F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
The clock assembly is item 1 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=42821
Close up view(s) Click pictures
http://www.appliancepartspros.com/part_details.aspx?part_id=4009450
Thanks for choosing FixYa.
Kelly
Oct 06, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
    hello,
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
    Lost my manual for chef condor integra oven - need to check auto functions and how to set them
    For TOuch Control oven:
    1. Press Finish Time touch pad
    2.press ^ touch pad until clock displays the required am or pm finish time.
    3. Press Cook Period touch pad.
    4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
    5. Press Automatic touch pad.
    Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
    7. Turn oven thermostat to desired setting.
    8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
    10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
    For Multifunction oven:
    1. Set time of day.
    2. Turn Function switch to Finish. 0.00 will be displayed.
    3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
    4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
    5. Turn Function switch to Auto. The automatic programme is now ready to use.
    Turn upper oven thermostat to desired setting.
    If keep warm function is required, turn function switch to Cook (optional)
    Happy cooking!
    Jun 14, 2009 | Ovens
    No gas to lower oven - Cannon Camberley
    Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
    May 07, 2009 | Ovens
    Setting the clock on my coffee maker
    After turning the coffee maker on press and hold down the timer button until flashing; then press the hour and minute buttons to set the clock.
    Dec 19, 2008 | Cook's Essentials Cooks Essentials Arome...
    GE gas stove
    sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
    Oct 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Tecnik 8525 Oven
    Press and hold the start cooking and end cooking buttons together while adjusting the clock with the + and - button. Once the clock is set you will not have a problem
    Dec 06, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
    MayTag Stove Model MES5770AAW
    Here are the codes for Maytag Ranges:
    MAYTAG
    Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
    Code
    Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
    Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
    Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
    Open Questions:
    Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range Logo
    261 people viewed this question
    Top Cannon Kitchen Ranges Experts
    paulcarew
    Vernon Taylor
     Mikey
    Mikey
    Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
