Question about DeLonghi DSM7 Stand Mixer
Electrolux Assistent I don't have a DeLonghi DSM7, but I do have an Electrolux AKM 5125, Type: N26. Saturday I made a double batch of chocolate chip cookie batter (without the chips included) in the white plastic bowl with the double beaters attached. I was using around 6 cups of white flour and and 4 cups of white & brown sugar, so the dough wasn't heavy as if I was using whole wheat flour. When I added the last of the flour, the machine seemed to be straining, so I let the flour mix in and I turned off the machine. The next day, I had one more batch of cookies to make and placed a cup of really, really soft butter into the bowl for it to beat. For the first minute everything was ok, then the double beaters decided to just stop rotating. The motor goes, but the main drive socket won't rotate. The drive socket located on the side of the machine (for the blender, etc) rotates just fine. I have had the machine for a little under 2 years. andersenna@comcast.net
1949 hobart a200 rebuild problem
Google Hobart --utube-ebay has 300 4sale somebody might know something--waiting on the chocolate chip cookies
Aug 02, 2017 | Food Mixers
Delonghi DSM7 Stand Mixer won't start after overheating. Is there a reset button?
take it in to an appliance repair shop for a proper diagnosis and quote but it is probably not worth repairing ( armature and brushes )
Apr 09, 2017 | DeLonghi DSM7 Stand Mixer
I can't get the tilt release to release to raise the mixer . I have a batch of cookie dough in the bowl and I am unable to raise the mixer
Try running the mixer for a few seconds to clear anything out from under the beaters, like a chocolate chip. You can also try pushing down on the beater end of the mixer, press the button and lift.
Nov 01, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Mixing blades detach while being used
type delonghi in the search bar. Pick a site and yell at them. Kidding, tell them your problem and they should work with you. Get a phone number and call them, get the salesmans name and a time frame you can expect repacements.
Oct 26, 2009 | DeLonghi DSM7 Stand Mixer
Runs fast for a few seconds , then runs very slow
I had the same problem and fixed it.
  1. I took it apart, unplug unit, remove the small black cover inside the stand portion, 1 screw. Underneath you will find four screws with a white plastic wire junction.
  2. Loosen two screws and remove the black and brown wires which connect to the control panel with the dial attached.
  3. Remove rear attachment cover, front top cover, and front delonghi cover.
  4. Remove top three screws where the blender attachment goes. Now remove the aluminum cover that covers the entire top.
  5. Slip belt off. Remove three screws with plastic washers that attach motor to chassis.
  6. Remove 2 torx screws that are located next to metal bar that keeps top half from swinging too far from bottom half.
  7. Now you can pull the motor out and the control panel with the dial. Remove the three slip on electrical connections on the control panel and reinstall. Carefully remove the two slip on electrical connections on the motor and reinstall.
  8. Re-assemble and test unit.
I thought I had a problem with the control panel or the motor, as it turns out the connections were the problem. Carefully removing them and reinstalling them solved the problem.
Jan 06, 2009 | DeLonghi DSM7 Stand Mixer
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Kenwood Chef Restore
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Need to find part for DeLonghi Mixer
Ask at the following link, I found there most of parts for DSM7 mixer.
http://www.forumappliances.com/
Good Luck
Jun 04, 2008 | DeLonghi DSM7 Stand Mixer
Motor Dead
I had the same problem the first time I tried to make a small batch of bagel dough (very small!) I had to send it back for repair and wait.....sorry that the news is not better.
Apr 01, 2008 | Viking VSM700 Stand Mixer
NO POWER! -- DeLonghi Stand Mixer 7 qt
There should be a overload breaker on the bottom of the motor, tilt it back and look for a little red (probably) button.  other than that, there shouldn't be anything else... if it doesn't  work, it might be defective... Don't give up hope though, those mixers, (used to be Rival, and made by Kenwood in europe) are *SOO* much better than Kitchenaid, it's not even funny *Grin* and good luck.
Oct 03, 2007 | DeLonghi DSM7 Stand Mixer
Problems mixing thinner batters thoroughly
Try a higher speed , this should force the batter out using the centrifugal force generated
Aug 18, 2006 | Electrolux 450 Watts DLX-N24 Assistent...
DeLonghi DSM7 Stand Mixer Logo
87 people viewed this question
Top DeLonghi Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a DeLonghi Food Mixer Expert? Answer questions, earn points and help others
