Question about Vacuums
Do you know how to change a emptor assembly
I've got a Kirby G4 and I need to replace the emptor assembly. Do you know how to change it?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=725050 Generic problem for all Vacuums… Do you know how to change an emptor assembly? Posted by smcgee on June 30, 2008 I've got a Kirby G4 and I need to replace the emptor assembly. Do you know how to change it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Kirby mini emptor assm can be replaced by going inside of the cloth bag and looking for the ty tie that is hold it onto the clothe outer bag and cut the ty tie to release the mini emptor on the Kirby. The bag @ the bottom has elastic around the bottom and should come right off; it will be tight but should come off. The front of the mini emptor has a gasket so make sure the new one has the same small gasket also, and that will just turn and unhook. You need to find a new ty tie just as long as the one you are removing; either from a local vacuum cleaner store, the Kirby Factory Cust serv (Parts) or try the Home Depot or Menards or a box store similar to those. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – U. S. & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
Kirby g4 power will not ingage
There could be a few reasons. Try a different power outlet and check the cord and belt. Next there are two safety switches on the Kirby that need to be engaged for the vacuum to start. One is on the mini-emptor to make sure an outer bag is engaged, the second is on the front nozzle to make sure the nozzle or hose is attached. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-755-6586
Jun 06, 2014 | Kirby G4 Bagged Upright Vacuum
Replace the mini emtor on a generation iv kirby upright
To replace a mini-emptor it should come of with a twisting motion. You may have to snap it if it is broken, and be aware in the exhaust port a piece may be left behind that you will have to remove to get the new mini-emptor to attach. There are 3 rivets that this part holds onto and when it is removed you should see the rubber and the 3 rivets. You can see pictures here: Kirby G4 miniemptor instructions.
GoodVac.com
www.goodvac.com
1-800-775-6586
Mar 19, 2014 | Kirby G4 Bagged Upright Vacuum
I have a Kirby G4. I have noticed the last few days when trying to vacuum that it is blowing more than it is sucking up. I put on a new bag to make sure it wasn't too full. I also put on the hose and...
take the mini emptor off(plastic piece on bottom of cloth bag) this is done by rotating it away from the body of the machine. There is most likely a clog there. Also take the brush head off and inspect fan for chips or cracks this will also reduce suction. let me know if you need further assistance
Apr 08, 2010 | Kirby G4 Bagged Upright Vacuum
My Kirby G4 won't turn on. Everything is engaged as I normally do it, nothing is wrong with my power outlet, changed my hepa bag to a brand new one...
It could be a few different things. First make sure the emptor tank on the side of the unit is pushed all the way closest to the unit. ck to see if light comes on (that will tell you if you have power to the unit.) if so It is an internal problem. Or it might be, what is called the power foot switch. It's kinda of like the brain for the kirby there are 3 saftey switches built into it. they must all be working at the same time for the unit to power. If need be take it to a vacuum repair shop one with free estimates. this way they can diog. the problem and give you a repair cost, if need be. Hope this helps.
Nov 13, 2009 | Kirby G4 Bagged Upright Vacuum
How to change Mini Em-Tor Fill Tube Assembly on Kirby G4
You will have to remove bag strap. You can try to save old strap (see instruction here) or you can cut it. Install the bag on the new mini-emptor just like it was on old one (strap goes over both layers of vinyl). Use a long cable tie instead of the strap if you have damages it or your old bag strap. If you are using old strap you may have to use pliers to get it in all the way.
Oct 27, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Sep 30, 2008 | Kirby G4 Bagged Upright Vacuum
Owners manual
Replacing old fan assembly
Sep 12, 2008 | Kirby G4 Bagged Upright Vacuum
I took my Kirby G4 outer covers off, vacuumed the inside to remove the dust and now it refuses to turn on. Is there some sort of redet switch?
I'm pasting this from another solution I posted. Hope it helps:
There are a few things to check:
There are safety switches mounted on the body of the machine designed to prevent the machine turning on when it is not fully assembled. Ensure that your bag unit is snapped completely into place, (with the rear of the emptor assembly nearly flush with the body of the machine,) and that the front nozzle assembly is mounted correctly.
Also check that the power cord (immediately aft of the bag unit,) is pushed completely into the machine.
If the switch does not feel responsive, it can either be that the little metal "pole" (for lack of a better description) is not attached to the main switch assembly correctly, which will require you to open the entire housing to check.
Those are the simple things to check, otherwise it may need a switch, cord, or motor replacement. Checking continuity on these items with a VOM will allow you to determine the cause.
-R
Sep 10, 2008 | Kirby Vacuums
No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
Jul 07, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
270 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
