posted by dobsonyi on Jun 30, 2008
I can control my television only with remote control. The buttons on
the top of the tv doesn't work - I can't turn on and off the tv, or
turn on and off the sound, changing channels. Can it be solved or it is
a manufacturing mistake?
Thx
f
Comment by dobsonyi, posted on Jul 05, 2008
yes, the buttons worked at first and when the problem turned out I read somewhere to turn off the tv for hours. Some hour later when the tv cooled down the buttons worked again.
Next day when I used the tv and it warmed up they didn't work.
Probably the heat causes the malfunction?
Best Solution
Did the panel buttons ever work?
if not mabey it was never connected inside the tv from factory
Rating Locked! (?) dobsonyi has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for Sony BRAVIA KDL-40V3000 Television
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
screen jump/bounce with main...
When using coaxial, video or... Answer This...
Buttons on tv panel
Buttons on tv panel
I can control my television... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
