I want your telephone number we just got high definition and a black line runs on the right side we have ownly had the tv for less than a year and is still under warrenty please reply with your telephone number
  • 216 Answers
Greetings mckerry56,
While being unable to provide you with a telephone number, since so many people support this site, I can provide you with some information you might find useful.
I would suggest calling either the manufacturer of the television or the retail establishment you purchased the television from to set up repair on the unit. If it is indeed under a year old, then it should be covered under the warranty.
I hope this helps.
Go Ahead. Use Us.
Posted on Jun 30, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ... > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Why are there Vertical black and color lines along the right side of the screen?
If you've replaced its LOT recently, the replaced one do not match with the original number. The fault is called 'Yoke Rigging".
Gopakumar Gopalan Google
Aug 11, 2014 | Proscan PS32500 32" TV
The screen on my tv is black on both sides
It's called a pillar box and it's normal when watching standard definition content on a high definition television. You can adjust this setting by pressing the format or pic size button on your original television remote or by pressing the zoom (bottom right corner) on your Uverse remote.
Oct 01, 2013 | AT&T UVerse
Black lines accross tv can i fix this
Narrow black lines across the set may be a problem with the panel edge connection. This is repairable, but requires a delicate touch to avoid knocking out more connections. I've done it on LCD panels, but not yet on plasma. I would expect the plasma panel connection to require extra care because of the high voltages required (with an LCD, I can massage the connections while the unit is running so I can observe the results; I'd be leery of doing that on a plasma set without careful evaluation of the method).
It's also possible, but less likely, that you have a problem with a row driver chip. If you have a wide black line across the set that is independent of the video format setting, I would definitely suspect a failed row driver.
Dec 07, 2011 | Samsung 50 in. Plasma TV
My Bush tv NR Itv 2101 on channels 1 & 4 picture is fine but channels 2,3, & 5 has a black band 1 inch deep top and botton. All channels say 4.3 so can't be that, any idea's. regards JM
it is because the channel is being brodcast in hd and not just digital. it is an unfortutane side effect of the dtv convertion, all brodcast are now digital but not all are high def, if you had a high def tv and were watching and standard definition channel it would have thick black line on the left and right because the image does not fill the dislay
Aug 14, 2009 | Televison & Video
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Black line
I just had this problem with my Samsung 50' DLP HLR5067WX/XAA. Fortunatly it was still under warranty with Best Buy, so they fixed it for me. They had to order a brand new light engine. (or where the mirrors are, if i'm not using the right terminalogy) He said the problem is with one of the mirrors that has slipped (or slipping because overtime the black line will get thicker and thicker). I hope i'm saying it right, but it was with a tiny mirror that was slipping. Hope it's under warranty. I've also had 1x component plug burn out on me, my HDMI port went to ****, and he's gotta come back out because when he made the repair, the picture was reflecting too high up and to the left. (MLB 2k7 for xbox 360 - scores on top of screen are about 1/4th cut off). He said is next trip back to my house would result in me getting a new TV, so can't wait for his arrival! good luck with your tv
Aug 10, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Horizontal resolution: 705 lines
This TV is NOT High Definition but the picture is as close to HD as you can get. It also has 1 S-Video and 1 Composite port which gives a GREAT picture! I have owned this TV for about 8 years and still love it!
Mar 22, 2008 | RCA F36648 36" TV
Televison & Video Logo
Top Televison & Video Experts
