My wireless connection is only saying attempting to authenticate can you help please
  • 40 Answers
It depends on what kind of security you have enabled for your router. It sounds like to me that you have not gotten the password right to join your network.
Double check your password and make sure caps lock is off, etc. If that is not the case , then try power cycling your router.
Do that by unplugging it, waiting a minute, and then plugging it back in. You may have to reenable your security measures but that should get you in...
Posted on Jun 30, 2008
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Not connecting to the internet
Router ?
Problems authenticating a router in a computer is a common problem when installing a router or if your internet service gets disrupted. It is easy to solve and only requires a few steps to fix. A router forwards data from a computer to a computer network. The network can be between multiple computers, such as one would need in an office. The network can also, and more usually in households, used for connecting to the internet. Open "System Preferences" in the Applications folder in Finder. Open "Network" under "Internet and Wireless." Click "Advanced" and select "TCP/IP." Select "Renew DHCP License" and click ok. Attempt to connect to the internet. If the internet is still not connecting, restart the router and try the steps again. b> For non-Macs b> Open "Wireless Network Connection" from the wireless tab at the bottom of the screen. Select "Change Advanced Settings." Choose the "Wireless Networks" tab. Choose the wireless network you want to connect to and select the "Properties" button. Under the "Association" tab, make sure the Network Authentication has the proper security level chosen. Enter your network key if your security code is anything other than "Open" or "Shared." Select OK and try to connect. Go Back to "Wireless Networks" tab -> "Properties" and click on "Authentication" tab and un-select the "Enable authentication for the network" selection if the network key is still not authenticating the router. Select OK and try to connect.
Hope this helps.
Jan 14, 2013 | Computers & Internet
Unable to connect to network
try to call product company and see if you can get authentication number
Jul 31, 2012 | Sony VAIO VGC-LS21N PC Desktop
I am using tp link adapter wn650g. i have two problems 1) when i click the tp link icon on the task bar it says authenticating on the link status. 2) although i have a 108 mb card but it always connect...
Hi!
The Authenticating status means that you entered an icorrect network key. The 54Mbps is the wireless speed that your card is getting from the wireless router. That means that your router can only broadcast a maximum speed of 54Mbps. This is usual for Wireless-G routers. Although your card is capable of receiving 108 Mbps, the router doesn't have that speed. The 108 Mbps can be attained if you have a Wireless-N router. To resolve the Authenticating error, try to reconnect to your wireless network using the TP-Link utility. Make sure to enter the corrent wireless network key also called as passphrase. If you are using WEP as security mode, follow the steps below
For Win XP
1. Go to Control Panel, Network Connections
2. Right click on Wireless Network Connection > Properties
3. Click on the Wireless Network Tab and at the bottom you'll see Preferred Networks
4. Highlight the name of your network and click on Properties. Click on Authentication tab then uncheck the option that says "Enable IEEE" something like that. Click OK all the way out
5: Check if that fixes it. You may also try to reboot the computer after that.
One more thing is you can try to change the Channel of your router. You can do that by connecting your laptop hardwired to your router then access router web interface
Feb 18, 2011 | Computers & Internet
When i connect to wifi it says authentication failed what does this meean?
Need to enter your WIFI security number entry is usually on the router itself if its common ATT router or the likes the ENTRY for the authentication is printed on router device
SEE WEP setttings WIRELESS ENCRYPTION
should be easy once you enter the security entry
PS your sure its your device you attempting to connecto and not neighbors WIRELESS ROUTER
Jun 11, 2010 | Computers & Internet
Attempt to go on wireless and get "need certificate" to continue. Any help for this?
Hi!
Here's the solution to your problem:
1. Go to Control Panel > Network Connections
2. Right-click on Wireless Network Connection > Properties
3. Click on Wireless Networks tab. Remove all the names under Preferred Networks box.
4. Click on Add button. Type the Name or SSID of your wireless network
5. If you have encryption enabled, uncheck the box at the bottom "The Key is Provided for Me Automatically".
6. Type in your wireless encryption key in the given boxes.
7. Now click on Authentication tab. Uncheck the box that has the "Enable IEEE Authentication".
8. Click Apply and OK all the way out. Restart your computer.
9. It should be able to connect wirelesly.
Jul 28, 2009 | Computers & Internet
Authentication timeout
Try resetting the configuration of the router by holding the reset on the back for about 10 seconds, then reprogram the authentication settings.
Please rate this helpful if it was!
Jul 03, 2009 | Linksys Wireless-G Broadband Router
Laptop says validating identity
Right click on wireless network connection and go to properties. From the Wireless Networks tab, choose your wireless network and then click Properties.
Click the Authentication tab. On the Authentication tab, Uncheck"Enable IEEE 802.1x authentication" for this network check box. and click oK.
Now reconnect to the wireless network and you will be able to connect to it.
IF you still face issue then please enable WPA encryption on the wireless router and that should work fine with both the laptops.
Rate it, if it helps.
Jun 27, 2009 | Belkin Computers & Internet
Wireless network connection, Intel (r) pro/wireless 2200bg says not connected. How do I get it to say connected? I have disabled it and then enabled it and to my surprise it still says not connected- How...
Try these first:
Make sure that the wep password is correct.
change channels to 1-6-or 11.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Feb 18, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
